Coil springs for AHC (2 Viewers)
Spacer do make a big difference with Kings. Much more so than with stock AHC coils. If you'd like to max sensor lift. I would then add either 20mm or 30mm spacer, depending on your weight and height you'd like. Note: You can stack up to 2 spacer, according to manufacture.
I'd would consider LC T-bars, if you've added weight like with winch and skids with that bumper. LC T-bars may not let you drop to low, if not enough front end weight at stock height. With just an iron front bumper and stock height (~19 3/8"), LC bars likely not needed.
You'll get benefits from this set up.
1) With your new globes, you should be able to dial in frt Mpa as low as you like 6.9Mpa, or even lower and not max the T-bars. Rear pressure, depending on weight and which spacer. You should be able to get ~6Mpa (before adding gear & people).
2) Reducing the pressure, by shift more weight to coils and T-bars. Will save AHC for when needed.
3) If AHC failure happens on the trail, you'll not drop to the rocks w/LC t-bars. (Carry a 30MM socket in your tool kit).
Note:
We set pressure and height, with full tank of gas and vehicle empty (no people or gear). You can play around a bit loading gear and checking pressure. Some do like to set pressure a bit on low side, unloaded. So that when loaded pressure aren't to high. It get into feel of the ride.
Great info, thanks for your help! After dialing down my sensor lift from max height to mid-way, my front pressures were low. After adjusting t-bars again I am at 6.9 front and 6.9 rear. This is with a full tank of gas, no passengers, on level ground. I have not unplugged the temp sensor for rear pressures, as I heard it was hit or miss. I am thinking the rear 30mm spacers combined with my King springs could get me to the proper rear pressures from my current 6.9. Thoughts or ideas? I will definitely look into the LC t-bars also but I am a little nervous as my driver side t-bar adjustment is a real pain to turn now. It doesn't appear to be cross-threaded but it is not easy to turn like the passenger side.
Rig is heavy for sure, build thread is: Cream Puff Build Thread - https://forum.ih8mud.com/threads/cream-puff-build-thread.1011395/
ARB front with winch, BIOR rear with tire carrier and hi-lift. Also have a spare in stock location for my trailer. Fridge stays in full-time and looking at doing a single drawer on driver side. So yeah, I got all the weight! That said I don't really need a max sensor lift, so moving that down a bit is fine.
I'd reduce rear height (lower sensor), to reduce rear Mpa to 5.6Mpa. Than determine if you like that height or would like rear higher. If you want it say 10mm higher. Look to see if sensor will slide up ~10mm. If so add 10mm spacer. Than raise rear (sensor lift) about 10mm. These are approximate measurement, and will give you end results you'll need to tweak a bit. You may find 5mm or 20mm lift suits you better. However much lift from the 5.6Mpa you like, install same width spacer. Than adjust sensor again, to get the 5.6 to 6Mpa are good targets. You can also load with gear, and look at pressure. If this rig used 70, 80, 90% off road loaded with gear. You can drop sensor a bit, to lower pressure when loaded. But unloaded it will be a little stiff and lose dampening if Mpa to low. Play with it all you like. Get to where it feels good to you. Just don't run in to high a pressure, or you reduce life of globes and ride may get to bounce. May even kick off ABS system (TRAC off alarms). Push pressure to high, and system will fail to raise or go into fail safe.
T-bars:
The left side of 100 series, is heavier. So LH T-bars is always cranked more CW turns than RH. It's the LH T-bar adjuster, that get maxed in heavy built rigs. Make sure threads of T-bar adjusters are clean and add some oil to threads. When cranking on T-bars, make sure to put AHC into H first or lift front end with a jack. This helps reduce weight on T-bars, make easy to crank on T-bars adjusters. I use either a 1/2 ratchet. Or if a hard tuning adjuster bolt. I use q 3/4" breaker bar w/30mm socket
We both mentioned re-indexing the t-bars. To be clear: I'm not talking about CW or CCW cranks on adjusting bolts of t-bar. I'm talking about removing T-bars and re-setting off factory index points, to get more CW turns on adjusting nut. I've never actually tried this. I've always worked to index on the marks factory or after-market t-bars give us. Matching into factory marks of each mounting bracket.
I'd wait to see how system performs, once you have desired height & pressures in front also. If than you find your maxing the LH T-bar, and system has difficult raising. Consider the LC bars. Especial if at only 3/4" rake and can't get pressure down to ~6.9Mpa. I'd add LC T-bar if with 7/8" rake I couldn't get to ~6.4Mpa. With the LC T-bars. You'll find adjuster will have lost of thread (adjustment) remaining and easier to crank on.
LC T-bars work very well. Allowing full AHC L to H, and good dampening. In heavy built rigs. i.e iron bumpers, winch, iron skids, bell pan, sliders, roof rack, frig, etc.
They may not allow AHC into L, with only and iron bumper and sliders. This may not enough weight, even with max sensor lift.
For heavy built off roads. LC T-bars are a must, to keep off the rocks IMHO!
Once set up, put a few hundred or thousand mile on it. Than adjust again. It will likely change. As system settle in and you've tweak it a few times. Each time you find setting changes less and less.
I live in my Land Cruiser full-time, when I was building it for this purpose I did it with an eye on the Max Gross Weight, which is approximately 7,000 lb.
I discovered that at this weight my pressures were way too high. Even with King Springs and 30mm Slee spacers, so I replaced the globes and flushed the fluid, that helped quite a bit. But I was still at about 6.9 in the front and 7.5 in the rear.
So yesterday I made the next step of installing non-AHC torsion bars, non-AHC springs, and replacing the rear shocks (mostly because they were rusted) and I wanted to report that it's a smashing success.
The ride quality has not been affected at all, my pressure's in the front are 6.3 and my pressure is in the rear are 6.6. After cross leveling, I have almost exactly 19.5' in the front and 20.5' in the rear. With 14 graduations in my AHC fluid reservoir.
The torsion bars and springs are actually fairly easy to come across because everybody who has a 2000 through 2005 Cruiser has upgraded from their OEM bars and springs. If you go to any Land Cruiser shop that's mentioned in these forums they will probably just have them laying around.
So in short, for very little cost, I was able to upgrade my 2006 to be able to carry a 7000 lb load and still enjoy the ride quality the ahc system provides.
Yep, I am running non-AHC LC100 springs in the rear for the last 8 years.
I need to check my pressures again, but I took 30kg of AGM battery out of the front and put a 13kg lithium in the rear.
Has anyone already asked? What's the difference between AHC and non-AHC springs? I just fat-fingered an order for AHC when I meant to order non-AHC. Will they be softer/shorter or the opposite?
48231-6A770--rear RH AHC
48231-6A780--rear LH AHC
48231-6A680--rear RH non AHC
48231-6A690--rear LH non AHC
You're going to need to adjust your order, the ahc springs are significantly weaker than the standard springs.
While researching replacement oem AHC springs for a friend of mine with a UAE spec 100 series with 1HD-FTE with a rear sub tank (I'm so jealous!) I came across this interesting observation. LHD 100 as a 15mm taller springs on the LH while RHD 100 has same springs on both sides.
48231-6A710 H=449.5, RED PAINTED ( GEN LX470 RH )
48231-6A720 H=???, ( GEN LX470 LH )
48231-6A730 H=???, YELLOW PAINTED ( USA LX470 RH )
48231-6A740 H=???, GREEN PAINTED ( USA LX470 LH )
48231-6A750 H=455, PINK PAINTED
48231-6A760 H=470, ORANGE PAINTED
48231-6A770 H=485, PURPLE PAINTED ( USA LAND CRUISER RH )
48231-6A780 H=500, BROWN PAINTED ( USA LAND CRUISER LH )
48231-6A790 H=515; YELLOW GREEN PAINTED
48231-6A800 H=530, LIGHT BLUE PAINTED
48231-6A810 H=545, WHITE PAINTED
I didn't see anywhere that anyone posted regarding the use of stiffer OEM springs like the Yellow, Light Blue, or White ones above (thanks @CivicFerio ). Has anyone installed these? Ideally I'd like to use a spring that's between the OEM and the Kings.
Could we find someone with access to a Toyota parts store, or someone with more info on Toyota parts, to find out if those higher numbered coil springs are actually for the AHC 100 series?. Looks like part numbers 48231-6A750 and up are for ahc, and part # 48231-6A710 to 48231-6A740 are for conventional suspension. I have tried 48231-6A770 and 48231-6A780, and know that those are for the AHC vehicles.
I'm running
48231-6A780 H=500, Brown spot now, on both sides, but still the pressure was at the upper half of the range, even when new.
If the
also are for the AHC equipped 100 series, it would be very interesting. I'm ready for one step up from brown.
Revisiting this topic as I would like to ditch the Airlift 1000 bags and add a "standalone" higher rate spring.
The 3rd row seats, belts and brackets have been deleted (minus 100 lbs) and the current approximate weights are as follows.
- Cargo load in cabin = 350 lbs
- Hitch carrier = 165 lbs (including all the frame brackets, platform, and pit bull restraint system)
- Sport bike = 400 lbs
- Total weight = 915 lbs (minus 3rd row = 815 lbs net)
Looking for some input on what spring rates to run with the AHC to get rid of the airbags and comfortably carry the weight. Can always throw in some heavy gear to help keep weight on the rear axle when the bike and carrier are removed. Maybe bags are the only way to keep the front end planted with that much weight off the rear?
Additionally, the AHC does properly function with this weight and can change from low too high, though going to high takes just a tad bit longer, but not too much. It's been a few weeks but I believe my pressures were at approx (f) 6.0 and (r) 9.4 Mpa loaded, and (f) 6.9 and (r) 6.1 Mpa Unloaded.
Info gathered from this thread is pointing to the non-ahc LC coils and probably a spacer added in as well. The LC coils should get me back down to 6.0-6.5 Mpa in the rear, and with a spacer a few 10ths more. The question will be how the front responds and will I get the same drivability I got with the air bags.
The air bags did a fantastic job allowing me to utilize my AHC with my custom motorcycle hitch carrier and my 400 pound motorbike, along with a few hundred pounds cargo load. The air bags kept the rear more stable and put more weight on the front end which was very noticeable through all the mountain twisties. Decided after a recent incident that I would rather not have to deal adjusting pressures during a last second need to utilize the height control function.
The New Orleans area was under nearly 3-4 feet of water in some areas and I was out in some of the deeper sections and decided to run in high. Of course, my air bags were filled just enough to shift with it and nearly destroyed a bag when I later returned to normal.
(The bike and carrier were removed at this point and had about 10 psi in the bags to assist with the load in the cab)
According to the EPC the longer length springs H=485 to H=545 are usually found on GCC VX models with AHC suspension, 3rd row seats, dual spare and auxiliary tank.
That's what I figured. My guess is that they aren't as "heavy" a spring as the Kings is.
KTRS-79s in mine, no spacers. Didn't check my rear pressures prior to installing them, however in a stock LX rear pressures range from high 4s to low 5s. Ride is a bit firmer - however not uncomfortable at all. Ideal for when we go camping with the rear loaded with gear and a 180kg (~400lbs) ball weight camper trailer.
  • Like
Reactions: uHu
I agree with @uHu !
I'll point out why and how to achieve your goals:
Spacer do make a difference, especially with Kings AHC coils.
Rear 7.7Mpa with King AHC coils. Indicates you've either heavy built rig, have a sensor lift or a combination of.
When we add weight like iron bumpers, etc.. The pressure goes up.
When we increase height, with sensor lift. The pressure goes up.
High Mpa means carrying more weight on AHC system (globes). Can also indicated globes weak/failing.
Low Mpa means carrying more weight on Coils & T-bars, than on globes.
Kings AHC Coils with vehicle at stock weight (3rd row and full tank of gas) & height (no sensor lift), will yield 5.4 to 5.8 Mpa rear. Add 30mm spacer and max height (full sensor lift), yields about 4.8Mpa.
I'd start by cross leveling front, by adjusting T-bars. Than measuring height of rear and marking location of sensor arm in slide, as reference points. Than adjusting rear sensor down the slide, until ~5.8Mpa is achieved. Once rear pressure achieved, measure rear height again. If you now find rear height to low for your set-up or desire, and would like rear of vehicle say 20mm higher. Add 20mm spacers to the Kings, and pressure will drop. Then raise rear 20mm, by adjusting the height sensor up until ~5.8Mpa archived. Than adjust rake, by adjust front sensors. Than adjust T-bars to get 6.9Mpa in front.
Notes:
  1. When adjust rear only, pressure changes in fronts just a tad. Or vise versa.
  2. If pressure to high in front, and AHC T-bars fully CW cranked up. You can re index AHC T-bar "some" to get a little more out of them. But with a heavy built rigs, I swap out the AHC T-bars, with the thicker Land Cruiser T-bars.
  3. Once rear height and Mpa achieved. Drop/lower front of vehicle height to get a minimum of 3/4" rake or more, by adjusting sensor. Then adjust T-bars to bring pressure to ~6.9Mpa. I like to carry a tad extra weight on the LC T-bars, depending on what rear comes in at and how much extra weight in front. So I may drop pressure in frt to 6.7Mpa.
  4. We do not want excessively high Mpa front or rear. As this indicates carrying extra weight on AHC system. If pressure high, globes life is reduced. To high of Mpa, and system fails.
  5. If King coils, spacers and LC T-bars used, and not enough extra weight. AHC system, "may" not lower.
Reminds me of corner balancing racecars!! Great intel. Thank you.
