I saw a picture of a of a co2 tank for filling tires. Who makes that set up?
Sent from my iPhone using IH8MUD
Been there, done that.
Bottom line:
CO2 is portable, fast, high pressure for seating beads but... CO2 is a finite source, you run out you are done. Want to fill your friend's tires? Maybe you have to say no so you don't run out for yourself. Going on a trip where you will need to air up and down a few times... will you have enough? 3 trucks airing up each day over 3 days is 36 tires worth of air.
Pump systems will give you air all day long (hey, if your truck isn't able to run you have bigger problems than needing a compressed air source anyway)
Mark
a 20# Co2 tank will last a damn long time.
How many 36x12 tires 10psi to 30psi?
A 20# tank...airing up my own truck at least 4, probably more in the range of 6, times.
I just don't air up
Works for me
Bottom line:
Mark
What size tank are you using?Been doing more multi-day trips compared to the trail runs I used to do. I'm looking to get a pump to free up space and well...I was "that guy" who ran out of C02 on a week long trip to MT. there are pros and cons, and after 5+ years with onboard C02 I may have moved beyond it. It IS FAST though.and with 33's it lasts a while for me. you just have to be sure you've topped it off before 8 days in no-where'sville.
