Anybody know what brand/model number volt meter will fit in a stock 67 fj40 cluster. My amp meter is dead. Thanks
Hi!, this is my first post, ive been a lurker in this forum for quite a while and i found this thread to be awesome, i do have a question, has anyone found a solution to the -50+50 Ammeter?, i have a 1981 BJ40 and the PO had removed the fusible link and soldered a big red wire instead, i removed that and made my own fuse link and pluged the ammeter to both ends, it doesnt move at all it only flinchs a little when i turn on the lights and the engine is off.
Welcome to this forum and welcome to the madness.
To my knowledge nobody came up with a solution for this (your) problem.
It's a design flaw. The Ammeter is not sensitive enough to show the voltage drop over the Fusible Link.
I hope that you still have the two 5Amp fuses in series with your Ammeter? If the Fusible Link blows, the full current will go to and through the Ammeter and that means smoke in your cluster if the two fuse are not present.
Rudi
Ive been doing some testing on that and yeah the current that goes trough the ammeter is really really small, when the lights are on the current is about 200x10e(-6) A, there is no way its going to register, the problem is that the only way that we can direct more current to the ammeter is by increasing the resitance of the fusible link, and to do that we should just increase the lenght of it, very strange...
...... the PO had removed the fusible link and soldered a big red wire instead, i removed that and made my own fuse link.
This 1962 gauge cluster is original and I noticed a few things different. Interesting. fjfjfj
I doubt if this is an OEM cluster. I think it's a very nice refurbish job.
And..... I must admit..... it looks good!
Rudi
I think the verry early (pre64) high beam light lense was green not blue. On mobile for now so I can post a pic...
Hello you guys,,,,,,,,,,,Here is a straight on pic of my gauge cluster. A little easier to see. Yes on green lense, whitish gray area around the bottom. As mentioned, original miles on the odom. An extremely clean original. I got lucky. Thanks bj40green for checking things out again. Let's see what gets weighed in here. Thanks everyone. Obviously I want the restoration to be period correct and unless I get more info I will be sticking with this age old cluster that I know has been in there, unchanged since at least 1965 and I think has NOT been changed since original in 1962, at least I know the odom never got touched and from our review nothing in that cluster got changed out. Thanks for everyones input. FJFJFJ
Hi Travis,
That must be the one from your '64 FJ40 right?
Is that the kit from Amaurer?
New OIL, TEMP and VOLT gauges and keeping the OEM Fuel gauge?
I assume that you want to point out that on your 64 cluster you have a Blue High Beam indicator lens?
Rudi
