For Sale Clean stock low miles can 1984 bj60 5spd
UPDATE: TRUCK IS SSSOLD
she's gone . . . outta my hands . . . buh-bye . . . don't think i'll find another like it....it was a pleasure owning this legend, even for just a short time . . . :crybaby:
With mixed feelings, up for grabs anyway is my 1984 LHD Canadian BJ60. I purchased this rig early this year with the intention of keeping her for a long time. Since then I’ve re-evaluated our vehicle situation after finding out we’re expecting our 2nd baby in the new year. We currently have a 2 year old as well. I’m considering a more practical cruiser or a diesel van that will get plenty of DD and recreation use. I’ve realized that she’s too nice to use as a DD and be exposed to our salty winters where she’ll eventually end up like the rest of them. The PO had a winter beater most of the time so this rig stayed in a warm garage and saw little use during snow storms….which explains why she’s in such great shape. Here’s a thread I started explaining more:
https://forum.ih8mud.com/60-series-wagons/421497-2nd-thoughts-practicality-owning-nice-bj60.html
DETAILS:
- 1984 BJ 60 (OK for US import)
- Only 238K kms (148K miles) and counting…
- 2 battery 12Volts
- 5 speed
- power steering
- Original factory brown, absolutely no paint fade
- ONLY 1 owner prior to me
- Maintenance records from the day it was bought
- currently on 245/75/16’s BFG TKOs on OEM JDM 80 series alloys (with matching spare)
- came with factory chromes rims on the stock tire size, in great shape (also with matching spare, so I have 10 rims and 10 tires)
- no AC, roll up/down windows, manual locks
- aftermarket flip up moonroof
Practically bone stock except for:
- Volvo shoulder belts in the rear (stock lap belt in the middle)
- aftermarket, but outdated, pioneer cassette deck with no clock!
- small old clock that also beeps when key is taken out with lights still on (sometimes it doesn’t work)
- small indicator light in dash when PO was tried to use a Volvo electric fan, then he went back to stock rad/fan
- and 2 driving lights with switch under left vent
- clear moonroof/flips up but doesn’t come off I believe
- tow hitch
ENGINE:
- Legendary bombproof 3 B diesel running smooth, clean, and strong, no smoke (except on start up which is normal). Meticulously maintained by previous owner, has never given him any problems. She pulls tight and cruises very nicely at 2300-2500 rpm, just purrs like a kitten, slow and steady she gets you where you need to be with a smile on your face and returning 23mpg (or 9-10l/100kms)
- PO used stanadyne antigel/fuel lubricant..i currently use gen49D by powerup every tank
- mild sweat and occasional drip not exactly sure where but never had to add oil anywhere (possibly oil pan?) a while back the IP leaked so that ran down and mixed with engine gunk/grease and could also explain the older drips
- has inline coolant heater for the winters, works perfectly, starts right up on one crank in the coldest weather
- minor repair on the IP by a local diesel specialist
Thread here:
https://forum.ih8mud.com/diesel-tech-24-volts-systems/355576-3b-ip-leak-diagnosis-pics-n-vid.html
- I’ll say it again, this awesome torquey 3B is tight, starts every time, idles smoothly, pulls with confidence and will run for a looooong time. I’ve heard they keep em running for 24 hours in some mines, that’s just nuts.
TRANSMISSION:
- what else can I say about the h55F 5spd….it works, it shifts smoothly and it’s solid.
- original clutch, no complaints, can take off on 2nd gear from dead stop. i've seen many with over 300K kms on the original clutch
- rig was never offroaded, as in “wheeled over boulders, water crossings, bounced off trees, etc…”….just camping trips with the kids and pulling a camper/trailer. if anything, the most action it probably saw was on a winter run i did over a snow covered sand pit...so i guess she did offroad once ;)
- transfer case shifts smoothly from 2hi to 4hi to 4lo and back, I’m confident it and the locking hubs got very little, if not below average use during it’s life
INTERIOR:
- the usual tear on left side of drivers seat from getting in/out
- the rest of the upholstery is in really good shape, vinyl all good, no other tears or holes anywhere else
- just slightly darker on the drivers seat from use
- all carpet in good shape (PO had to trim edges behind bench for Volvo belts)
- roof liner in great shape, odd small stain here and there, but no rips or tears
- no cracks in the dash or on the doors
- overall, very nice shape
EXTERIOR:
- in really good shape for its age except for some small bubbles forming over back window and along a couple spots on the drivers side rear fender, and very small early rust on the bottom of inner door frame
- except for that parking lot rash on the gas cap area, fuggg!
- the worst body rust is behind the drivers side wheel well, about a 1.5” hole that should be a relatively easy fix
- theres light surface rust on the window frame
- some small stone chips on the piece behind the front bumper, but the hood is almost perfect b/c the PO installed a hood deflector when new, I was the 1st one to remove it
- roof and roof rack are mint
- there are two holes and a small crack on the sideview mirrors b/c the PO also installed these extra concave mirrors so he could see more
- ALL glass and windshield are crack free, no tints
UNDERCARRIAGE/FRAME:
- solid and no rot, just surface rust
- rear frame rails and rear crossmember bar are SOLID, I took a ballpean hammer, screwdriver, and wire brush to different areas and it only revealed good metal underneath ( I wouldn’t have bought the rig if I didn’t like what I saw underneath)
- rocker panels are solid and no holes
- everything is caked in grease after 26 years of religious rustproffing
COMES WITH:
- 2 shop manuals
- the original brochure!
- owners manual (and even the inspection sheet from when it was sold)
- factory work light still in it’s bag that plugs into the dash
- bottle jack and tool kit/bag (but not entirely complete)
- 2 spare belts
- oil filters/ fuel filters/ air filter
- front rotors/pads/and front axle seal kit
- (I may or may not include the 5 16” alloy rims/tires dependingon the sale, I could still use it on my 80 and roll on 255’s…..we’ll see) Will try and clean up and polish the chrome rims and take a pic, just mild oxidation
WHAT WORKS:
- all the lights (glow plug and filter indicator light work), gauges, heater (I’ve never felt such a strong gust of hot air in any other vehicle), fans, hazards, reverse light, dash light and dimmer
- parking brake, all windows, all locks, all doors, moonroof, mirrors, horn
- rear/floor heater blows hot
- the volvo shoulder belts retracts nicely, the front belts just need a little coaxing like in most older vehicles
- front locking hubs are perfect and turn with ease
WHAT DOESN’T WORK:
- left turn signal cancel, just have to flip it up yourself, blinker works
- antennae pulls up and down but the last small piece came off, still have it, minor
- rear washer doesn't spray, but wipers and defrost work fine
WHAT IT WILL EVENTUALLY NEED:
- front axle re/re
- and might as well new rotors/pads while there….current ones are still okay, and just pulsate a little
- suspension (but currently I’m fine with how she rides still on the original springs. I have seen many many 60’s in my area still on the original springs…but boy would it be nice riding on 2.5” ome’s!)
I am asking $9000 CAN or best reasonable offer. or $9500 with extra set of 5 rims/tires
If she’s headed far away then buyer is responsible for shipping costs/procedures…but I’ll do my best to assist on my end (I’m really not familiar with this type of transaction)
I have seen what’s out there for sale, there are only a handful of these types of rigs that pop up from time to time…the rest have frames and bodies needing serious repair, and have serious high mileage, but those dang motors are just so indestructible!
Sorry for the loong ad, just trying to get as much info as i can and be transparent at the same time..i've got nothing to hide and would love to see her go to good hands and making the 3rd owner happy. :)
Thanks for looking.
Cheers.
Romey
speakin of wvo (waste veggie oil). i have seen and wheeled with rigs running on them (2 buddies have bj60's running on about 10cents a litre after all the overhead). this system is relatively simple to put together. lots of info on mud for svo/wvo.
i've heard good things about these 2 companies.
PlantDrive™ - WVO, SVO vegetable oil fuel system, gas alternative, biodiesel
Greasecar Vegetable Fuel Systems | Greasecar Vegetable Fuel Systems
or do it yourself. eitherway, the savings will more than cover your parts/labour and put money in your pocket in the long run, and she'll burn carbon neutral and smell like fries :)....i was hoping i'd do it one day cuz the inline pumps for these are great for it, ah well.
or, you can add with the diesel filtered waste veggie oil (some say up to 50%) w/o heating it! so if there's a local supplier for dewatered/filtered veggie oil, i know you can purchase it for much less than diesel (i think the greasecar site lists wvo dealers all over NA)....or filter your own in the garage. add a cubie or two every tank and save while lubricating your fuel system.
just another fyi.
ah run it in your hdj81. Your pump will be lubricated and a DI diesel copes better than an IDI diesel.
Nice 60 btw!
thanks man! i did drop a bottle of canola oil once in the 80 just for kicks, it ran okay...:) there's a plantdrive guy out west that's done the conversion to 3 or more hdj81's i think using a manafre aux tank...that's just sick!
cold start yesterday morning...about 5C/40degreesF. inline coolant heater not plugged in yet. guess you'll have to take my word for it, that engine was cold. :) that humm (soundingn like a blow dryer) in the background is some street cleaner and not my rig.
84BJ60 :: MVI_5528.mp4 video by steadyburn - Photobucket
Nice BJ 60, I remember being a teenager looking at the BJ 42s and BJ 60s at Waneta Plaza Toyota in 1984.
Wasnt until 1988 until I got my 1980 FJ 40. I wanted the diesel but at those times we had gas wars like 9 cents a liter so @ 12-13 mpg it was quite economical. Thanks for showing the broshures.
Bump
thanks prado t!
yup, she's still here. just flipped my sons car seat so he get's to watch me drive now :)
got a local fella seeing her next week and a contractor is checkin it out too to see if it'll haul his materials/tools okay..although i have mixed feelings with this thing being used for that....:meh: i get it though, lots of room and diesel, great for on the go jobs. claim the vehicle purchase/mileage when its tax time...makes sense.
This is a beautiful example of a Canadian BJ60, very well maintained.
Good luck in the sale Romey, for that money it is a steal. I can probably get you a better deal on shipping by rail if we run it under my company.
cheers
oooh, cools Wayne, that'd be a great idea! thanks for that kind offer! guess we'll see where things go. still love love driving this thing though!
had an older fella from australia who used to have one just like it in Oz check it out and he was impressed with the condition...but he couldn't commit to the sale. ah well.
some interesting offers though on top of the odd low baller; a trade for a low miles 2002 landrover disco II V8 from one fella and a 2006 saab 9-3 2.0T from another!!! wtf?! no gracias. lol.
but yeah, i will be torn if/when this old girl moves on....
cheers.
I am wondering also if this one is still available, very nicely documented, manual diesel. Best for the money, but still a bit steep for my personal finances. Still, if you are really flexible, 'cause I don't want to insult anyone with a low ball, give me a call. Otherwise here is a boost for what seems to be a great truck.
Best wishes, Madogeoff
i saw it again last weekend.
it is one BEAUTIFUL example of a Canadian survivor.
i think he said it was sold to some bloke in Quebec but not sure.
tentatively sold fellas, i've had 3 serious buyers in line for the last couple months, busy holidays, and STILL debating whether i should move on from it! so didn't bother updating it. when it's final, i'll post up . . . i'm still tryin to find reasons to keeping her as i'll know i wont find another like it...i will cry like a little girl when this one goes...ah well. this just means that whatever replacement it gets, that will go to the wife, and the 80 will be mine again, muahahahaa!
thanks Wayne! "canadian survivor" is exactly it! :)
UPDATE: SHE IS OFFICIALLY SOLD
