Hi fellas,
So I j ust recently picked up a relatively low mileage 84 bj60 with 228K kms (less than 2 weeks ago)..and I just started noticing a leak in the IP. Upon inspecting the rig twice before I bought it, I made sure to look here for leaks, it was dry during both times I saw the rig, and one was a cold morning start (and no diesel odours).
Anyway, since taking ownership I noticed a puddle under the rig, smelled like diesel, and smelling diesel all over But the leaks have been intermittent. I spoke to the owner who has been quiet truthful (in my eyes) to see if he had had any issues with the Injection pump, and according to him he’s never had to touch or adjust anything on the pump (and I know he’s meticulous and would certainly have addressed this, and logged it in his maint. notes which he’s had since brand new, so I’ll believe him). Anyway, the rig’s always heated(relatively warmer) garaged parked and driven less than 10K kms/year approx. since owning it, I’ve parked it outside in the very cold…is it possible that the seals have shrunken in the cold and caused this leak? I remember that when I looked at the rig it was warmer (we had a warm spell) and now the temps dipped again to below freezing.
Anyway, lemme know what you think of the pics..
Just this morning before start up…
And after start up you see where the fuels coming out off…
vid:
I’ve used the search feature in did find a couple threads on it potentially being an easy fix, and that’s to tighten up the nuts on top of the IP (and there was some mention of colder weather affecting the seals). I’ve looked at the FSM but didn’t find any troubleshooting things, just major IP removal and calibration/testing instructions. Now, I’m a newbie when it comes to these things but eager to learn. I’d also hate to strip anything cuz I know some of these parts are almost unobtanium!
So just to make sure, if it just needs tightening up, which should I tighten? The bottom nut (A) and/or the top smaller one (B) at the base of the fuel ines going into the injectors?
So remove lock plate (C), and righty tighty the delivery valve holder (A) and/or the smaller nut above it (B)? I just want to make sure I don’t strip anything, or do it in the wrong order…
I believe (D) is a bleeder valve, that’s tight too, how ‘bout (E)? but clearly you can see the leak coming out from the delivery valve holder (in the manual it holds the delivery valve and seat which I think is the source of the leak?
I’m hoping I don’t have to go to a full IP rebuild/benchtest/recalibrate…?
I’m hoping the next newb doing a search finds this too…
I’d greatly appreciate your tips and advice!
Romey
vid:
Romey
