I personally don't care if the lid latches. The cup holder could be removed if you want to close it up.
I personally would not care about the lid thing either, but I have a feeling others may care. I want to design this in a way that keeps everyone happy. That may not be an option. Version 3.0 will tell me if I can do this AND allow the lid to close.I personally don't care if the lid latches. The cup holder could be removed if you want to close it up.
Taking this foam one step further, I had 2 mismatch self drilling screws with nice flat heads and removed the factory cup holder and zip zip... 100% better than I expected. No interference when installed and holds my tall hydroflask. Pic shows the nice screw. The other well, looks bad but, works.Mine arrived recently. Overall they work good. Mine had a bit of play for and aft, but after adding some non-slip grip pads they are solid. Overall good work!
These 1x4" strips are the perfect size for the rear of the inserts.
Don't Lexus drivers drink that Fiji water in square bottles?
That is probably the path I will go if I can't make this work with the lid.Would the option to remove and replace the whole cup-holder assembly be better?
While I have a LC and the current inserts would work, I'd be more interested in having a better designed (e.g. deeper, adjustable) assembly.That is probably the path I will go if I can't make this work with the lid.
Whats the easiest way to pop out the center cupholder assembly?
I would always buy those over priced Fiji Bottles for my 80. hahahaha, With good intentions of refilling them a dozen times. Then, I'd lose the bottle.Don't Lexus drivers drink that Fiji water in square bottles?
