Choke Cable trouble
I have a 1973 FJ40. I've had this rig for only about a week. I set out to lubricate the clutch cable. Now I can't figure out how to reattach the cable to the linkage. Part of my trouble is I can't see what I'm doing.
I have the wire lubricated now and it slides nicely. I have secure the exterior cable in the set screw. I just can't figure who to secure the little bent wire into the hole of the screw on the linkage. I'm completely lost.
If someone could provide a photo that would be awesome.
Thank you,
Victor
buy a factory service manule. life savers they are...
Thank you,
Victor
@Victor LaPorte :
Picture from my 1973 FJ40 with stock everything. I'm assuming you are enquiring about a choke cable, like your title, and not a clutch cable, like your message.
@Victor LaPorte :
Thank you. Yes choke cable not clutch.
Your set up is different from mine. I’m guessing some sort of rebuild, maybe. The former owner is ghosting me so I can’t ask him. On yours, the wire that passes through the hole with the set screw is different then mine. There is a screw but it faces the fire wall. The other end is a nut. It floated in a brass fitting. The wire comes through and hooks into the hole. I think it is designed to be held in by tension. This discussion has given me another thought. I will try and photograph it next week when I visit it in storage garage. I really appreciate the photo!
Finally figured out my problem. The wire goes into a tiny hole and then the set screw holds it in place. My issue was I just couldn't see what I was doing. Not my best effort, but it's fixed.
