rusty_tlc
Dain Bramaged Member
Is it the plate that you weld to the "horn" on the front of the frame?Mace, Planning on the sag 4 turn, garden variety gear box. Seems that people have good results with it. Rusty... Picked up the mounting plate from OrangeFJ45. I do remember that there was VERY LITTLE clearance between one of the pulleys and your steering shaft. Hence the concern. If the motor is set, there is not a whole lot of options (it seems) to route the steering around. However, now that I think about it, that gear box and plate set up will ONLY go so far into the engine bay... K
I'll look at it tonight but IIRC it's the fender brace that the linkage rubs on.
Anytime you want to come over and look/measure at my engine compartment your welcome. It might help you visualize how this stuff is going to go together.
