Unfortunately this grease does not have any molybdenum additive in it, so according to the 80-series FSM it would not be suitable. Looks like a good grease for wheel bearings though.
Sorry about that.Wheelingnoob said:I have used that Nemco brand in two axle rebuilds now with good results. Used the Moly3 from Cat in the past and I cant tell a difference.
If the Valvoline Palladium has the rating and the Moly% to be right for the birfields and it's wheel bearing rated why would you need to run two different greases?
93Chewbacca said:There have been discussions about this. Most of them end with a decision on whether people are comfortable with running molybdenum in their bearings. I've never seen any proof that having molybdenum in wheel bearings caused any problems.
Fair enough, I'm going to use it in both applications and we'll see how it goes!
klstclair said:Hi 93Chewbacca,
I have been following this thread and the one you started on Bob is the oil guy and have found the Lubriplate SYN 3002 you recommmend available in tubes locally. I am getting ready to do the front and rear axle rebuild and have a couple of questions.
1) When you did your last service with the Lubriplate SYN-3002 did you use it for the wheel bearings as well or did you choose a seperate type of grease for wheel bearings?
2) Would it be appropriate for the rear axle service as well ?
3) Approximately how much grease was required?
Thanks,
Kevin
Hi 93Chewbacca,
Thanks,
Kevin
BCR4619 said:It said 5% on the front so I said why the hell not... Especially for 5.49!
My local Chevron Cardlock with a storefront, they stopped stocking it on the shelves but you just have to ask them to order it in and it's usually takes a week or so to get it.
They also have a 3% version.
When I get around to it I will pull up a data sheet unless you beat me to it.
Added a link to the data sheet at the top of this thread. Thanks!![]()
