Did a LOT of searching and found tons of helpful info. But i need a little more help. I have a 72 fj40 with an F motor, alternator is mounted on passenger side after gm powersteering added. My battery will die after sitting in the garage for a couple weeks. With a 100% charge on battery, i can drive it around with lights on for 3 hours, turn it off, come back an hour later and the battery is dead. So here is what i have done;
Bought new battery, new voltage regulator, Alternator tested good at the shop, starter has good ground to frame. Checked voltage with key in run position on the following- F terminal at ALT with plug plugged in 5 volts, F terminal on plug while unplugged 12 volts, ignition terminal on voltage regulator is 5 volts.
With key off and everything else off, i dimmed lights in garage and pulled negative battery cable to look for spark, there was no spark, did the same thing with positive cable, no spark.
Checked resistance between F terminal and ground on battery, read 0 OHMS.
Used a jumper wire between B+ on ALT and F Terminal while plugged in to ALT, slight spark, but read 12 volts, there was no slight jump to 14V. Tried jumper again with F terminal unplugged and stayed at 12V. I used the multi meter to perform all of the above tasks. I tried using the led indicatore alternator tester for the last test (B+ jumper to F terminal while unplugged and i got a slight jump up to 13V. only right when i removed the jumper did i get a slight jump in voltage with the small spark. Wondering why the LED alternator tester picked this up but the Multi Meter didnt?
Pinhead, coolerman, anyone have any ideas?
