There was a really good thread on swapping charcoal canisters for an after market one. I can't find the info. Mine is toast and I want a new one rather than just swapping the hoses.
Thanks.
Thanks.
Actually... Swapping the hoses will also slightly lower your mpg too. The engine will no longer be sucking in air when ventilating the canister while driving, which normally leans out the A/F mixture to where it's supposed to be.
The engine will run a bit richer swapping the hoses.
What aftermarket canister have you found to fit your batmobile?
Looks like some of the 80 guys are having this canister installed with no issues.
J
Amazon.com: ACDelco 215-153 GM Original Equipment Vapor Canister: Automotive
Amazon.com: ACDelco 215-153 GM Original Equipment Vapor Canister: AutomotiveDo you know if that's the same dimensions and would work on the 60. I checked locally at O'Reilly and autozone yesterday and both said it was unavailable from their warehouses and not available from the vendor either.
