I’ll check my records for the brand and cost and post back after 7pm CST tonite including how to mount using the original FJ62 canister brackets sans plastic tie straps
Where did you get it
Excellent, thank youI’ll check my records for the brand and cost and post back after 7pm CST tonite including how to mount using the original FJ62 canister brackets sans plastic tie straps
The Vapor Canister I used was manufactured by Standard Motor Model No. CP3029 and sold by Autoplicity at a retail price of 139.27. Ok, it’s costly... but ruggedly all metal. I was able to use the original OEM Mounting Brackets by using EMAGNETS Adhesive backed tape (.60 mm thickness and 1” wide) applied to the top and bottom of the canaster in a thickness that equates the necessary difference beteween the old and new canaster diameter.
It’s a simple and very clean installation.
Showing available online at AutoZone for $48. If this one will work: https://www.autozone.com/engine-management/vapor-canister/duralast-vapor-canister/239708_0_0
Rock Auto - $57 https://www.rockauto.com/en/parts/airtex/wells,4B1004,vapor+canister,5180
Would love to hear from anyone who has installed either of these to understand any mods required to make it work.
You’re Absolutely correct, Willard. UNBELIEVABLE, Huh! I bought my vapor canister just one year ago. There was a time when I bought (2) of everything when replacing a part to avoid obsolescence, ergo... horrendous price fluctuations. Even bought Cruiser parts when I knew I would eventually replace “down the road” as they say. Hence, I now have over a $12,000 inventory of mostly OEM/NOS parts in my garage. As both the Cruiser and I mature (over 30 years of cohabitation) I believe it’s time to let the next owner “maul” over these “long life” quality replacement parts and the never ending price inflation. I’d like to bequeth the Cruiser Goldmine to one of my Nephews but none of ‘em know the difference between a “ wrench” and a “Wench”! In the meantime...keep the faith! We’re in a new era of quality replacement parts with some still manufactured or remanufactured by original Toyota suppliers!
Mine has a purge and tank nipple on it. I ran my tank line to the tank nipple and tee’d that with the carb vent line. The purge goes to the vcv. That’s how I dealt with going to a two nipple canister from the original three.
Elbert,
If venting the tank is your only need then a venting gas camp will work.
I did the hose swap on my OEM canister about a year ago, and since this last winter I've been losing a lot of fuel through the tank cap. I've checked the gasket on it and everything seems kosher, so I'm wondering why it's belching out fuel. I need to go ahead and do the charcoal canister replacement and I'll get a new cap anyway since they're cheap. Hopefully one of these solves the issue because I would like for it to not be spewing gas when I start painting it.
Turned out to be the cap. New one stopped the fuel leak. Still haven't replaced my charcoal canister yet.So, how'd it go?
