Just a cheapie $2 unit from Autozone.
Thanks
Or if you have no emissions, vent-to-atmosphere. Plug off the connection to the intake and put a lawn mower fuel filter for the other end off the hard line and call it good.
But I never said that.....
Yes, 6 comes after 5.
1st gear + pedal to the floor = 6k
Needle was maxed out.
My wife kept asking if I was trying to blow it up.
When we got down the other side and got to the light she freaked from all the smoke coming off the brakes, thought the engine was on fire.
Had brake fade coming down and she didn't want to stop.
But that's another issue.
Just did this last night. Worked as advertised...
Im seriously considering removing Charcoal canister if there are no ill effects. I live where there are no emissions, can someone please describe the routing of the three hoses. It's not made very clear in the posts, Thanks
After reading a bunch of threads and searching for a canister i too bypassed mine. I even tried swapping the one from my 94 (not running) only to find out i have 2 .com bad cc's. Maybe i get around to fixing them as others have done at later date. Either way i plugged the purge (to engine). I then connected the hose from tank to the one that runs out the bottom. I used a fuel filter from my 68 mustang to join them. I bet i have the only LC with a chrome fuel filter replacing the cc! Check engine light off and no more gas leak. Any legit saftey concerns ? This is my wife daily driver?
In this way would one run the vent back down to the frame? I know "a guy" who did this and he's getting strong fume smell in cabin at idle.Or if you have no emissions, vent-to-atmosphere. Plug off the connection to the intake and put a lawn mower fuel filter for the other end off the hard line and call it good.
I went ahead and ordered the one from autozone. I was using a cheap inline fuel filter and plugged the intake line. Was getting a lot of fume smell while sitting at idle. Don't run it straight to the intake, feel like thay would pull more vapor than necessary and possibly make you run rich? Just a guessLooks like we know the same guy ha ha...
Would there be anything wrong with just putting a vacuum cap on the hardline? I assume the cap would pop off before the tank ruptured...
I was also thinking of connecting it directly to the intake manifold to suck those fumes up into the engine...
Anyone have any thoughts?
You went it to atmosphere and you get spark somehow underneath your car and then you have a nice fireworks and you watch your car burn down jus so you know gas fumes ignite like gas
That was my point, fumes will ignite really easyFor the record, gas doesn’t burn very easily. Gas fumes on the other hand burn very easily.
