Last weekend, I grenaded my T/C (91 FJ80). I got a good take out from a local guy that parts out FJ80's, but he kept the CDL motor, so I swapped mine over.
Because I knew it was in a locked state when I pulled the old one out, I rolled the gear on the replacement T/C into the locked position before swapping the motor over.
Now, everything is back together, but the replacement T/C CDL won't unlock.
I tried disconnecting the plug on the rear output shaft (pass side, top), per instructions found on iH8mud (they said this should revert to an unlocked state). But no luck.
My questions are -
1) Is the CDL motor a pwr locked/no pwr unlocked configuration? Or is it pos/neg LOCK - neg/pos UNLOCK?
2) Does this motor ONLY run full lock/full unlock internal to the motor OR is it a run one direction to lock/the other to unlock until something else in the T/C tells it it's fully engaged/disengaged?
3) Do I need to remove the CDL motor to get it to clock correctly (ie motor locked AND T/C locked simultaneously)?
Additionally, there were 2 wires damaged in the removal process, that are now repaired. The first was one of the wires fir the neutral switch broke off right at the plug. I was able to source a new plug with ~2" wire, and soldered this to the harness on my 80. The 2nd was the yellow wire coming out of the top plate on the CDL motor. I soldered this wire back together. So, both repairs were done with solder/shrink tube, so the repairs wouldn't be an issue (ie bad connection).
Another point of interest worth mentioning, even though the CDL light on the dash is lit up, if I hit the manual dash CDL switch, the indicator light seems to get brighter
My questions are -
