I used a 3-jaw puller to remove the gear on my pump when I rebuilt it.. turns out the clearance between the gear and the face of the pump was tight enough that the jaws of the puller dimpled the face of the pump very slightly.
I didn't notice that until I went to reinstall the pump and it wounldn't sit flush.. wouldn't even really start going into the bore. I spent more time than I'd like to admit trying to figure out why something that came out so easy wouldn't go back in.. until I saw the little bumps and filed them down.
Point is.. the round inner face is quite a tight fit into the bore the pump slides into. If anything happened like my rebuild I could see it getting jammed and cracked.. or weakened during a previous install.
Next time you got to rebuild your pump used a bearing separator to remove that gear instead of a 3 jaw puller, the separator doesn't leave any marks. It slides right in between the gear, and the pump body, then you use your 2 jaw puller to pull on the separator to remover the gear.
Since the pumps housing is made of cast iron, my best guess is that it got dropped on that mounting ear, causing a hair line crack to form. Probably happen at the place where they rebuild them, you just happened to be the unlucky sole that owned it when it broke.
Amazon.com: OTC (1123) Bearing Splitter - 1/2" to 4-5/8": Automotive
I wasn't talking about getting the bearing off the shaft, but in fact removing the pumps main drive gear on the front of the pump. You know the gear, the one that everyone has a hard time holding still while trying to remove that 12 point nut.Is it not easier to drop a deep well socket over the shaft and give it a tap to separate shaft from bearing?
I held the shaft in the vise with 2 pieces of wood.
