You'll never get those bushings out in one piece.Here are my alignment numbers as of today.
Alignment check was free so that’s pretty cool
Definitely too much castor with the plates and the bushings.
My plan now, is to flip the 2nd bushing in each arm, upside down/ turn 180 degrees. Maybe that will give me enough clearance and reduce the castor a bit. Considering that the icon bushings are rated for 4.6 degrees of correction which is a ton of correction for bushings.
At this point it all about trial and error really.
If flipping the bushing does not work, I will replace the bushings with stock ones.
IF that still doesn’t fix my clearance issue then I will remove the metal techs and get some Land tank 2.5 plates.
If I still have clearance issues after all that, I’ll just drive the 80 into a swamp and leave it for a gator habitat.
Just buy new OEM ones now and install them. That will solve the issue.
