Would like some assistance on how best to correct my Caster angle. Currently -0.3* on the front left and -1.6* on the front right.
1979 FJ40 with a 4” lift on 33” rubber. Spring perches do not appear to be modified. Based on the larger than stock tires I would like to shoot for about +2* of caster. Open to recommendations here.
The lead guy at Midas said I can only correct Caster on the vehicle by moving the axle forward and that a shim rotating the caster angle would not do it. If he were the guy sitting next to me at the bar I would dismiss this, but since he has 20 years at Midas, I am looking to see if his impresssion that Caster can not be corrected with an axle shim is correct.
Last piece of advice sought: I could put in a different thinkness shim on each side, though to more closely align the left and right side caster. E.g., 2* on the left and 3* on the left. What are your thoughts?
Thank you for your help.
