- Thread starter
- #21
That's the quick easy math behind it to dispel the theory 14mm = 2 degrees of caster rotation. But it's not all the math. It will be slightly less than that.
You say <2 degrees & pinhead says 4.3 degrees. Who's correct?
I have a std suspension and hight is 520mm from centre of hub to under the guard
my caster at this point is left 1.42 degree, right 1.38 degree
if I do the 14mm slot what would my caster be
if caster is 3 degree std why is mine those numbers
from the bump stop to the diff messures 50mm which is what the manual says is correct
all the hight measurements are right
regards peter
Peter, do you know how to add?
Man, every thread I see you posting on you are being a dick to ppl. What's the deal. Your knowlege is inferior, we know. Guy is just asking a question. You either help him or just move on, not insult his inteligence. Don't forget there was a time when you started off and needed answers. Geez.
EDIT... Guidance/help spoken from a true proffesional. (Landtank)
EDIT... ^^^^ Guidance/help spoken from a true proffesional. (Landtank)
you have also told me to buy new parts as well that didnt help, like a power steering box that you said was stuffed, i took it to the shop and got a new one 900 bucks later and the guy said it was fineI've wasted plenty of time helping Peter out for your information. If people aren't willing to even add 2 numbers together and try to learn. Can't hold their hand all their life.
i took it back to stock to get std factory setting, as you said, did i have a reading before the lift was put in
anyway i find you dont explain your self properly to people that dont understand, you need to learn more people skills
end of convensation
