thanks Pin-Head for clearing that up,very much app.The Toyota caster spec is 3 degrees, plus or minus 1 degree, so it is a range of between 2 to 4 degrees. 50 mm off the bump stop (what Toyota calls the follow spring clearance) is a little high, since the spec is 36 mm. This height alone would cause a caster change of approximately - .8 degrees, which can account for your slightly out of spec caster of 1.4 degrees.
can too hard a springs in it cause a few problems, aas my springs are made for constant weight but most of the time its empty. theres not much give in the springs if any at all
regards peter
