gregnash
Anal Retentive Analyst
Ok I am finally breaking down as I really want to figure this out.
This time last year when I rebuilt my topend I also rebuilt the carb. Since then I have had an on-going issue with tuning the carb so that it will HAPPILY idle below 1k rpm.
Used the proper kit from Kurt at Cruiser Outfitters and replaced the secondary diaphragm at that time with a NAPA one. BeBe runs great but just will not hold a consistent idle down around 650rpm like she used to.
Now this isn't saying that I cannot get her to idle down at 650rpm, she just won't do it happily, idling smoothly and what not.
This has finally gotten to the point where it is starting to piss me off as I know it is eating gas because it wont idle right. I spent the last two days adjusting the timing and everything per the manual but still cannot get it to idle below 1k consistently.
Anyone got thoughts or a good way to baseline a carb for tuning?
Current setup...
- truck is fully desmogged minus recurved dizzy and carb
- idle is set to right at the BB when vac advance is disconnected and plugged
- Fuel mix screw is at exactly 3 turns out from just barely seated
- idle screw seems to be just touching the arm
So at this point I am not sure where to turn next other than pulling the carb for a second rebuild to see if something is stuck/sticking or completely swapping out for a trollhole.
If video is needed I can see about putting something together.
Current setup...
