Funny you should say that...Where's the video? I'm bored at work.
Thanks I appreciate your honest comment. But again, 'faking an idle' ?? Meaning off choke correct? And honestly 200 rpms? A nearly 30 year old truck, hmm. When I get mine all back together I'll be very curious to see if mine would idle that low.
Im also wondering if the AC Pump, since I didn't soak mine in oil, has a tendency to stick a little to the walls of the AC pump area. Thus when it is going down (returning to idle) it sticks and skips a bit.This line of thought makes sense. My cable op carb does the sticking links on the way back down to idle thing. I'm assuming it is in the linkage on the carb. A stiffer spring will just give you a shin splint. Might try hitting the link side of carb with some slip plate.
Oh I know .... Been posting unfinished threads for 5 years myself. I had just popped the popcorn though.Get used to it. Mud is the home of the unfinished paragraph.
I am actually currently working on an install right now. Once I get that taken care of my plan is to drive back to February 1987 and buy my truck brand new with a ton of new OEM parts for everyone on MUD for 1980's prices. Now, if I can only get above 60 mph....My FJ40 made a noise like that. A new flux capacitor fixed it. You should try that on your FJ62. They're totally the same.
Have had a similar high idle issue since three years. Read threads, tried many things. Recently bit the bullet and took the Aisan carb (Aussie 3F petrol model) out and apart for a clean and rebuild. Had the reassurance thta the carb was ok but the high idle issue was still there. The last test i did was to try a different throttle return spring and oh boy wjat a difference that made!!! Drives like a different car, the revs actually drop down to around 700rpm every time i change gear - i have to learn to drive it again!... wait, what happened? It's like watching a TV series and they ended it just before the finale....
15 months and no one asked him if there was a resolution?
