I’m new to the forum and FJ’s. It says it’s 79 but I’m not sure if that is correct.
Not much to see in that pic.
Engine block is 74-newer.
Valve cover is 78-80.
Carb is 75-78.
The head casting date is on the top of the cyl head, alongside the valve cover.
Block casting date is harder to see, located on side of block, toward rear, under the manifolds. Best way to see it is with camera held down there
Poster is in Florida, loads of South American 40’s down there that have been “restored” for sale in the States. More pictures would tell the rest of the story.It's a south American Cruiser. Seeing serial numbers at that point for me is worthless. I see very little stock anything.
There is no plate there in these South America versions. This is one.Should be a plate inside the drive's door with the assembly date and VIN.
If it was originally exported to South America instead of the US,
Should be a plate inside the drive's door with the assembly date and VIN. Also a plate on the passenger fender behind the battery with VIN and engine. (and the VIN / frame # stamped on the front of the passenger side frame rail).
If it was originally exported to South America instead of the US, there will be differences on what updates on parts and changes occurred in what years. I have seen pictures of 2F engines from even the '80's that still had the alternator on the drivers (left) side even though all trucks shipped to US apparently had it moved to the right / passenger side in 1975.
And, looking at the 3 relays mounted on the plate where the fan would typically be, the coil and the GM power steering pump, many of these vehicles have been modified over the years and even if someone did understand what part were originally used for vehicles shipped to wherever this went in that year, it's possibly changed since. Maybe the whole engine, maybe just parts.
So, if you are needing help verifying what parts to buy, I suggest mentioning specific parts and including pictures of that part. The whole engine, or whole vehicle, is probably of limited use...
Yup. Run. Keep looking.
Correct there is no VIN on the A pillar. That was North American market. 78 and later the VIN plaque under the hood moved off the fender and back to the firewall where it was until the mid sixties when moved to the fender. US market FJ40 in 79 would have a model number FJ40LV KCJA. From that could tell it was six cylinder petrol, LHD, hard top, four speed, ambulance doors, roll bar and last the A at the end would tell it was for the US market.
While doesn't have the VIN plaque on the A pillar it should have one on the firewall. Would be located toward the top just right of the vertical brace on the left side looking from the front. The brake booster suggests it has drum brake on front and back axles. US market has disc brake up front starting with the 76 model.
Thanks Jim. I need to order some parts and wanted to make sure it’s a 79. I’ll try and locate the numbers. Much appreciated.
It was originally exported to Colombia. A friend who is Colombian help me fix it up there and brought here. I was having a problem starting it in the AM. I would add a little fuel to the carb and after that it would start with no problem, but if I let it sit for a day it was the same thing. Found a small leak on the fuel line past the filter and fixed it. Now it’s good. It drives great but I have some minor things that need to be done. Thanks for your input.Should be a plate inside the drive's door with the assembly date and VIN. Also a plate on the passenger fender behind the battery with VIN and engine. (and the VIN / frame # stamped on the front of the passenger side frame rail).
I’ll post more pics when I return. Thanks.Poster is in Florida, loads of South American 40’s down there that have been “restored” for sale in the States. More pictures would tell the rest of the story.
