Also, with a factory Toyota FF you risk shearing the axle studs on the end of the axle shaft. So
ARB studs, Long axles with 4 additional dowels or larger studs will pretty much solve this issue.
I've heard that the factory Toyota FF has a smaller cross-section than a SF axle, so the "strength" is roughly equivalent. Don't know for certain though. Also, with a factory Toyota FF you risk shearing the axle studs on the end of the axle shaft. So
With broken studs one wouldn't be "dead in the water". Would they?
Enough said...And don't forget the MUD10 discount code when you order them
A couple of comments I should make since I make these flanges...
1st off, someone quoted $1400ish for converting to everything new and compared it to buying a used FF setup? How is that a fair comparison? Also, where is your parts source for an axle never sold in the US? This is simply a bad comparison since I have never met an owner that didn't have tons of used parts and sources for more. This is $250 in common parts used at the most except the axles and for the axles try Branik Motorsports for a much better price with the best quality.
2nd, a FF is stronger in that it is not pre-loaded with the vehicle weight. Pure and simple...
3rd point, How are disc brakes worse in snow and ice and an enviornment that salts the roads? The backing plate alone would rust away before anything disc related. And when adjusted properly how are they actually any different except that you stop in a shorter distance?
SOR will have my parts and axle, when in stock. Buying used is a non issue with me. My Ebay account proves that. Drums on the back doesnt bother me.
Thought that is with discs in the rear.
Enclosed workings (for the most part) vs. exposed workings in a position that sees lots of salt spray kicked up by the front tires. Dealing with seized bits on the front brakes was bad enough when I first got my cruiser.
im geussing you want full floating to increase towing capacity? how much would that be?
I personally would never tow with an 89" WB. You would increase capacity but my goal would simply be strength and inexpensive disc brakes.im geussing you want full floating to increase towing capacity? how much would that be?
