Looking good Cam. Lots of so called, "professional shops" work would not be as good.
Amen.
What's your labor rate to do #2?
Amen.
I saw this on some other threads, so you don't lose your brakes if you stall (hopefully a non-issue with the auto), you need a check valve on the vacuum line from the intake to the brake booster. Here that is, shown with the reducer needed to connect the two lines...
I may have spread some bad info. It seems there's already a check valve in the Toyota brake booster....in the 60 series, at least.
Like I said before, I had to overthink the fuel fittings because it was new territory for me.
Here's the new filter/pressure regulator & it's fittings...
These fittings have two o-rings that make the seal, and usually a plastic clip that holds them on the hard pipe. The plastic clip made me paranoid, so I opted for the kind that screw together.
Thanks for linking this thread! It reads like a 'how to' for exactly what I'm trying to do to mine.
You are sooo close - you must be dying to fire it.
Again lots of great info here and I hope you don't mind if I hit you up with lots of questions.
The first one...got a part # for the fittings you used in this post?
Thanks!
Ed
