Midday update:
- Swapped over distributor - NO CHANGE
- Swapped over Ignitor - NO CHANGE
So to date, I've done the following:
- Cleaned all grounds and + terminals
- Swapped ECU with my Spare
- Swapped Wires, Distributor Cap, Rotor with my Spares
- Swapped Coil with my spare
- Checked the AFM per the FSM and it passed every test (see post for info)
- Set timing back to 5 degrees
- Tested Fuel Pump Voltage at the pump, noted it was low on high flow, hot-wired to get 13+ volts to it at high flow. NO CHANGE
- Check Engine Codes have not returned since the original post
With everything above checking out I think it's safe to say the issue isn't in the ignition side. Here's some more info that we noted while testing it today:
The stumble happens under 3/4 to full throttle (load) more noticeably / harsher at 2500 - 3000 then less harsh but still noticeable at 3000-4000, and not discernible above 4000 rpm.
My buddy who is a super secrete squirrel black ops UAV helicopter engineer/fabricator, who is also the dude that let me borrow his 80, said it felt fuel related to him. I've got a spare fuel pump and fuel pressure regulator in my bins that I'm going to bench test and throw in tonight, other than that I'm thinking injectors or wiring?
I'd like to get a data logging oscilloscope for my iPad so I can log when each of the injectors are getting pulsed during driving. But since it doesn't happen under light load through the same RPM I doubt it's a wiring issue. I'm thinking it's a sticking / failing injector since low fuel pressure would probably result in more noticeable issues at the top end rather than down low.
Oh, and I have a text out to my bud who I sold my old 93 to just to see if I can borrow his AFM and rule that out.
How does my logic check with you guys? Thoughts? Am I missing anything?
Whats my next diagnostic step?
- Verify Fuel Pressure at the rail? I'd need a remote gauge so I can see it while driving
- Buy one injector and just move it down each cylinder to see if I find the dead one?
- Replace the fuel filter (50k on this one)
