Trunk Monkey
Moderator
Hey everyone,
This happened on my ‘03 LX470 the other week and here are my comments:
First: posts #33, 114, 154, 177, 297, and 336 were super valuable, as was the YouTube video. Thanks everyone!
Second: I had it towed and they didn’t use a flatbed truck; they raised the back wheels on “dollys”
Third: my wife and kids were up camping and I needed my truck to tow the trailer home, but the wait for the part was about 2 weeks (I’m in Canada, had to import the part from California, much harder to source for ‘03-‘07)...so had to come up with an interim solution. For anyone in the same predicament as me, here’s how to get up and running without a replacement part:
- take it all apart like the video and posts say, except remove the white part completely as well.
- get the broken piece out
- stick a properly sized pipe down the throat to disengage the steering lock. I wrapped the ends in duct tape to make it more snug and toggled to the left to ensure the lock remained disengaged
- connect your immobilizer and hold your key near it
- use a screwdriver to turn the ignition on the white part
I was a bit nervous but the pipe was so snug it wouldn’t budge, it was my only option and it worked. Got the trailer and family home today and will be getting the replacement part installed this week.
Thanks for the reply. Sorry, I guess I wasn't clear. The broken rod has been removed already, and I removed the white piece behind it.You should be able to remove the white wire/switch unit completely off the ignition housing and trun the blade (the remainder) of the broken rod while moving the steering wheel little to either side.
Use a long screwdriver and press in the metal tab that has been pushed out towards the radio. At the same time try to turn the wheel to make it free from lock.Thanks for the reply. Sorry, I guess I wasn't clear. The broken rod has been removed already, and I removed the white piece behind it.
DUDE! That worked! Had to mess with it a bit but the steering wheel unlocked and I slid the part in. Still lots of work to do but another hurdle overcome. Thanks so much!!!Use a long screwdriver and press in the metal tab that has been pushed out towards the radio. At the same time try to turn the wheel to make it free from lock.
On the starting. Believe you are correct on the immobilizer is the issue on not starting. Going off memory...make sure than immobilizer ring or that little plug back in the slot is plugged in. It cant be dangling down or it wont be close enough. Cant answer to the rod. Maybe pull out rod and compare size on the notches.I am attempting to make the same repair to my 2001 LX470. I got the part number matching replacement from ebay, and after a lot of work finally got the old piece out and the new rod in. However, I have two issues: Turning from lock to acc is quite hard, but it will turn. I have no idea why this would happen, but maybe the ebay rod is not quite perfect? The other, more serious issue is that while I can have the engine turn-over, it will never start. Not sure if some kind of immobilization kicked in or something else. Anyone have an issue with engine not running after the replacement?
Thanks so much! You were exactly right.On the starting. Believe you are correct on the immobilizer is the issue on not starting. Going off memory...make sure than immobilizer ring or that little plug back in the slot is plugged in. It cant be dangling down or it wont be close enough. Cant answer to the rod. Maybe pull out rod and compare size on the notches.
I have read through a number of pages and it seems that the OEM PN for my 2003 LX is 45280-60610 and not 60510. These part numbers are for the whole assembly. Can/will anyone confirm that the rod I need to extract from the assembly is the same for my 2003 with power telescoping? I am not trying to shortcut reading the whole thread. I'm genuinely confused. Thanks in advance.
I appreciate your response and certainly don't want to ruffle feathers as the FNG on here, but I'm asking if the difference between the 60610 and 60510 part numbers are in the housing (throw away for this project), or in the shank (critical piece for this project). The 60610 part is available local at the Lexus dealer for $450 and the 60510 is $150 cheaper at the Toyota dealer. Again, not being snarky. Just trying to save where possible. Not sure I want to wait for shipping from UAE in the ebay link you shared and I will attempt to use your socket mod to limp the car home at least.Toyota Land Cruiser Lexus LX470 OEM Upper Steering Column Bracket 45280-60610 | eBay
Lexus LX470 2002-2007 (UZJ100). Toyota Land Cruiser 2002-2007 (UZJ100, HDJ100, HDJ101). LEXUS GENUINE. TOYOTA GENUINE. GENERAL INFORMATION.www.ebay.com
Says right there in the description that’s what you need. Just order it up and put it in it’s a quick project.
My 20 dollar eBay one is working fine as wellI got my full bracket for my 2000 LX from my local Toyota dealer for $199. Part # 4528060510 fit my telescoping LX just fine, same part as Lexus spec. Just extract the rod.
Ended up getting the aftermarket rod by itself from ebay and never used the Toyota one.
