NortheasterRunnerDo you have a pricelist for the SuperPro bushings?
I recently replaced all bushings with OEM rubber. I had poly bushings in the lower control arms and they don't last and the ride is harsh. The difference in ride quality and noise is dramatic.
What was your tab for doing this? I'm inclined to use OEM when I do mine, as I KNOW they will last a long time, and I think the rubber will allow for better flex over Poly. I also hear too many stories about how poly just flat does not last. My truck has 223K on the clock, I assume on the original bushings, I'd really prefer not to do it again...
One thing all owner need to be aware of, seeing as these trucks are now all over 20 years old, and have changed hands who knows how many times, and been worked on by who knows who. When working on these trucks, don't assume any nut, or bolt you remove from your truck is the original correct hardware. The reason I say this, I just helped a friend do a front axle rebuild along with front brakes. When we replaced one of the calipers we had a problem with one of the caliper mounting bolts not wanting to torque to spec. That bolt snapped off, upon inspection we found that "someone" sometime in the past had replaced the correct high strength bolt with a lower strength one. So for your safety it pays to check all your hardware before you reinstall it!Op, what was the cost of the new bolts after the originals would not tighten? These are really beefy bolts. Did you go back to mr. T or source from the hardware store?
I'm doing all of my rear suspension bushings with OEM. I'd hate to add even more cost to the job although Partsouq was HALF the price the dealer wanted at about $25 a bushing.
Also, do the bushings need to be oriented one way or another?
Nice thread. Thanks for pics.
