- Thread starter
- #21
Attempt at seam repair...
Well, in the process of cutting out my rear sill and beginning to try and teach myself to weld, I'm also beginning to try a "patch" process to repair these wheel cover seams.
Cutting out the corrosion, removing what rust I can on the wheel cover seam and treating with Metal Ready (POR 15 stuff). Then a bit of weld primer (in the areas I don't need to weld). I plan to later hit the new seams with POR 15 and then seam sealer (top/bottom) before painting.
Using 4 patches (18 ga) per quarter seam. More work but I didn't like the idea of cutting out a large part of the quarter and having everything move around.
Everything at the tacked together stage - I may try to stitch weld from the inside. Time will tell. Worst case I'll scrap the quarters if things don't come together. Of course the grinding will take forever ...
