- Thread starter
- #41
I've got the exact same fender/turn signal spot - except on the passenger side. That's a big slug of rust that's eaten into both pieces. Need to remove and patch/replace the spot-welded support piece on the bottom, patch the body and then weld the bottom enforcement piece back on. When I do my fenders I'll make additional patches if you can wait until HFO
(is Olive inside most of the time)?
The windshield frame of course has a good amount of rust inside and it would no doubt be a lot more involved than the fender spot. If you're going to all the trouble of pulling the window frame - the glass should probably come out. To do it right the whole frame could be dipped and then any other problem areas fixed - there must be more going on inside the frame. Again I'd be open to helping - it's just a schedule thing.
Did you replace your front bib at some point?
Off topic - if your 78 has a stock jack can you get the numbers off it for me (or a picture, etc.) I've searched and can't seem to nail it. - Thanks
(is Olive inside most of the time)?The windshield frame of course has a good amount of rust inside and it would no doubt be a lot more involved than the fender spot. If you're going to all the trouble of pulling the window frame - the glass should probably come out. To do it right the whole frame could be dipped and then any other problem areas fixed - there must be more going on inside the frame. Again I'd be open to helping - it's just a schedule thing.
I could get the work started and just have you make the patches and weld them in. I could grind down the welds after as well. I just want to use you as a crutch so I don't have to learn to weld.![]()
