Fine looking passenger side battery tray there. Very fine.
I have the painless wiring setup, but only bought their isolation solenoid wired up to a Toyota rear heater switch. The switch has three settings 1. Charge both batteries with engine running and isolate the batteries when the engine is off 2. Isolate the batteries regardless of engine running or not. 3. Combine the batteries regardless of the engine status for a self jump or boost during heavy loads.
Total cost was $ 90 for the solenoid and $20 for the Toyota switch.
I haven't started moving stuff yet. I plan to get a Blue Sea fuse block (I can't remember the exact name) and Blue Sea bus bar for all of the grounds. I am using the Blue Sea stuff because it is easy to work with and readily available at Academy and West Marine. It seems to be pretty well made too since it is designed for marine use.
I'll admit I didn't read carefully all of the above yet, but based on the OP I'm wondering why your ground cable is much smaller than the positive on the second battery.
