I've been wanting to get a dual battery system going for quite a while now and I have been slowly acquiring parts over the last few months. Well, I'm finally done.
My criteria for a dual battery system was:
1) Low cost
2) Simple operation
3) Simple installation
4) Safe isolation of house loads from recreational loads (winch, fridge, lights, etc.)
5) Ability to self-jump (with cables for now)
I shopped around quite a bit and considered National Luna and Hellroaring, but I opted for a 120 Amp Automatic Charging Relay Blue Sea (PN 7610). It is sealed and it does not require any user input or switching once installed and most importantly, it was way cheaper than the alternatives (about $78 on flea bay).
I also needed a second battery tray (got it from 'Mud), a battery (also from 'Mud), battery hold downs (from local Toyota place), 10' of 1 gauge wire, 1' of 6 gauge wire, conduit, crimp-on cable ends, stainless self tappers, zip ties and electrical tape.
The installation was very straight forward. Once I decided where to put the Charging Relay everything else was quite easy. I put the relay high on the firewall above the brake booster in order to keep it as dry as possible during water crossings.
The wire routing was also very simple. I used 1 gauge from the main battery to the "A" side of the relay. I ran another length of 1 gauge wire from the "B" side of the relay to the positive terminal of marine battery. I grounded the marine battery with a 1' length of 6 gauge wire. The relay itself was grounded to the firewall with a small ground. All of the connections were protected with heat shrink and conduit where possible.
The total cost breakdown for my budget 2nd battery system was:
$78 for the relay
$15 for the battery
$45 for the battery tray
$30ish for the hold down hardware from Toyota (next time it will be tractor supply!!!)
$12 for the wire
$3 for the conduit
$.80 for the tape
Grand Total:
$183.80
Here are some pics ...
1) Low cost
2) Simple operation
$78 for the relay
$15 for the battery
$12 for the wire
$3 for the conduit
$.80 for the tape
Grand Total:
$183.80
or
Ed, nice writeup...I too have been collecting parts and will dive into this in the Springtime. Simple fits the bill.
