Hey Mud,
Joined mud a month or so ago and figured I might as well catalog my build like all the cool kids around here. The plan is to make my FJ60 into a daily driver with ample ability to tackle some Pac NW fire roads and get to the prime camping and hiking locations. This is my first foray into Toyotas/cruisers and have found a massive amount of helpful information on this site.
Work began on the DB (dirty bird) right away and plan to keep going as long as time/funds are still available. Starting with my big to-do list; some I have already completed and those I plan on doing. Will add pictures and links to everything I can as I go and of some of the work I've already done.
Step 1: Get it running
-Clean gas tank and line w/ KBS sealer, replace pick up (DONE)
-Clean and adjust carb (DONE)
-Change oil and filters (DONE, will change again after 200 miles or now more...)
-New plugs (DONE)
-Check vacuum lines (DONE)
-Got it running, driving and idling
Step 2: Makeroad worthy/DD ready 90%
-get 2ndaries working (DONE)
-Continue to tune carb (DONE)
-new thermostat, she's running a little hot (DONE)
-Set timing (DONE)
-Check gear/tranny/transfer case levels
-Check tie rod ends/steering coupler/clean up slop in steering
-Clean/check brakes
-Attach battery tie down (DONE)
-Replace/Fix horn (Done)
-Clean upholstery (DONE)
-New wipers (DONE)
-Costco floor mats (DONE)
-Replace steering damper (Done)
-replace shocks (DONE)
-LED dome/cargo lights (DONE)
-Properly inflate tires (DONE)
-BFG All Terrains (DONE)
-DESMOG! (DONE)
-New Muffler, Thrush (DONE)
Step 3: Repairs and "Necessary" Upgrades
-Roof rack (Done, was the first thing I bought because priorities, Smitty Bilt craigslist special)
-Lube/Replace window felt
-Paint seat brackets (done on Drivers side)
-Install new seats (BMW 3 series)
-Install new spring bushings (sitting in a box, waiting for them to install themselves)
-Build sleeping platform (Built)
-Fix/remove pillar spot light (broke it, so removed it)
-Build wind screen for roof rack
-Add winch to Front bumper
-Remove and clean all carpets/ or replace entirely (Have carpet, just need to install)
-stereo and speaker (DONE)
-New rear hatch pistons (DONE)
-lift kit (Craigs list OME special)
-Rust repair (and more)
-re-paint (maybe gray or factory color)
-Sound deadening (done through doors and cargo area,
-Install headers (have, just need to install)
-Install new CAT (need to order)
-Repair Dash (complete but not successful, bunch of new cracks)
-Fix AC (fixed, but now it leaks...)
-Tint windows (done DIY, 35% ceramic)
-Buck
-C
Step 2: Make
-g
-Check gear/
-R
-r
-Buck
I thought it ran pretty good before, but was I apparently still missing out. It run smoother and has a very noticeable increase in power. Still needs to tune the carb and likely mess with timing a bit more but I am crazy happy with the results.
ed. Luckily I stopped on a downhill and was able to push-start the cruiser in 2nd, and make it out to my folks.
