Not that I know of.I have everything bled. Did pretty much what you said but did not disconnect the LSPV. I will give that a try. Are there any videos online that show you how?
Pretty straight forward. Remove one bolt from the pivot on the rear axle and the use wire or bungee to hold it in the highest position possible.
Two man bleeding, pressure bleeder, or vacuum pump bleed?
