kind of off topic question, but where did you get the 54mm socket to get the rotors/pads off????
also how long did the OEM pads last you?
I got the 54mm socket from Amazon
Amazon.com: OTC 6612 Heavy-Duty 54mm Hex Locknut Socket: Automotive
I cannot believe you spend the money on quality oem pads then put antisqueak spray on them....tsk tsk.....big no no. Toyota recommends against this due to the spray being causing debris to stick to pads and possibly causing seal damage to calipers. That stuff is snake oil like belt dressing and such don't waste your time just use the factory shims and if everything else is in good shape you won't have a problem.
This time around, I didn't use any silencer and didn't notice any squeal until I made my usual water crossing through the trench near our house
I'm @ 188,1xx now and I notice a bit of squeal after heavy rainstorms and driving through deep puddles, but it's probably due to the old ragged out shims more than anything![]()
Just curious, I've put a little over 30k miles on my rig and a complete PM was done right before I picked her up....
I figure since I do a bit of towing nowadays, I'd replace the pads before the wear indicator sounds off just to be safe
Well, today yanked the old ones out and they still had quite a bit of meat on them
Is this considered normal for 30k+ miles?
Mind you, I have a heavy ass roof rack with a bunch of gear
Rick
(~25,000 miles)
that noise could be from the pad seperating clips..one of mine broke one time and it was making a scratch sound.I got my fronts done in May, and I'm hearing the scratching noise when I drive. Unfortunately, having 9 cents in my checking account is preventing me from getting them changed. Go me!
And my gas light came on when I was driving last night.
my oem pads come green painted like that aswell..LOL
That's what they looked like out of the box...
I did cover them with red silencer spray before installing though...
Wow - that's really good on 80 series pads. Do you recall what kind they are?
I was only getting about 15K before the wear indicator sounded on a stock truck. The 100 series pads are doing much better for me now.
