Cruiserdan used to say "gotta feed my dogs". Wonder what Joey's line is?
"Gotta feed my overheating problems"
Joey, Thanos would like to return his turbo! It no workie.
might need to figure out some better EGT's.
So you're calling Thanos a liar?If I had to guess I'd say that is 20 years of intense heating/cooling periods. You can see the grain structure on it, basically turned the carbon into a ceramic. Don't drop it.
Pretty much spot on with that guess. This turbo wasn't actually used as a turbo, its been getting around the net the last few days on most car sites/forums I'm on. They used the hot side to circulate air inside a glass furnace.If I had to guess I'd say that is 20 years of intense heating/cooling periods. You can see the grain structure on it, basically turned the carbon into a ceramic. Don't drop it.
Well that explanation takes all the fun out of it. boo!Pretty much spot on with that guess. This turbo wasn't actually used as a turbo, its been getting around the net the last few days on most car sites/forums I'm on. They used the hot side to circulate air inside a glass furnace.
Why even wait? Just install the damn thing unless your smog is like around the corner. Otherwise just bolt and enjoyAny update on CARB testing? I will have the engine back together this weekend and it will be lonely without the new turbo.
Right? It’s bolt on after all.Why even wait? Just install the damn thing unless your smog is like around the corner. Otherwise just bolt and enjoy
My understanding is that Joey is waiting to ship to CA until CARB cert? I do not have a turbo on hand, so, cannot install one. I do not have to smog my vehicle biannually. I live in an area outside any Air Quality Management Zone. I only have to smog if I sell it, which will be never.Why even wait? Just install the damn thing unless your smog is like around the corner. Otherwise just bolt and enjoy
You could send me your kit and I can send you mine when it ships? I could put that kit to good use right now.Well you got nothing to worry about then lol. I'm in CA myself and had my turbo kit for months now (1st batch) of turbos sent. I just haven't installed it yet since I'm pairing it with a fresh rebuild. Fairly soon I will be firing it up for the first time.
I'm glad to see for your sake there has been real demand for your kit
