ARCHIVE Bolt-on HMMWV H1 Wheels (2 Viewers)
DavidinAZ, .......keep in mind these are CNC machined from a solid piece of billet aluminum. It is not a "cheap" way to build the adapters, the ARP hardware that comes with them is top notch stuff. The end results is a very strong adapter that will last years and years, and something you can put on your truck and drive across the country, go wheeling, and then drive back with no issues.
I'm sorry if it sounded like I was trashing your thread. I have no doubt it's a great product, and this setup is something I'm very interested in. I was simply caught off guard!
To clarify my statement not saying at all they aren't worth the $$, that's a ton of work and research on top of material cost, again well done and thanks for doing it! Another thing to think about is overall cost of a 37" setup. Someone may have said something before, but going with the military wheel/tire setup and these spacers would be cheap for what you get. I'm all over it when I'm able. Not for everyone I'm sure but a great option to have.
No worries, I didn't think you were trashing the thread. I was just explaining the reason for the cost.
Yes, if you actually want to go with 37" tires, or a double beadlock wheel (or both), then this is a great option that will give you an unbeatable great performing setup while still keeping the overall cost down.
Cheaper is only cheaper until you have to throw away your new recentered rims after they refuse to balance. Then you get to buy these spacers like you suspected you should have the first time around.
"There's never enough time to do it right, but always enough time to do it twice."
I think you guys are reading my post wrong.
This is exactly what I meant. Recentered wheels are not cheaper in the long run. I probably could have typed that a little more clearly. I would definitely purchase spacers before I'd recenter wheels.
Minus the OP and his parts, which are very nice, there is a crazy amount of bad information in this thread.
You guys do know what affects your wheel bearings is where the center of the contact patch is?? It has nothing to do with the spacer. If you kept stock wheels on and put 4" spacers it would space the contact patch 4" out. But if you swap a wheel with 4" more backspacing and put a 4" spacer on the contact patch is right in the center of the hub and won't affect bearings at all.
Thanks!!:o I did NOT know that.
Mahalos and well said. I just needed clarification in my mind.
Now the search is on like Donkey Kong!
Sent from my hawn finga using IH8MUD
Please do tell...inquiring minds want to know...
H1 Wheel Spacers
Baktasht, would you be consider giving me free shipping if i order a set now? Sold my 33 earlier today when i found out that your spacers are available:bounce::bounce2:. Pm me on how i can pay, i have my Visa ready for you:cheers:
Wow I guess I missed this the first time. The military double beadlocks from militaryoffroadtires.net are $39.95!!!
http://www.militaryoffroadtires.net/product-p/h124bw.htm
So you could do 5 double beadlocks (5@$39.95)
your adapters ($749)
16.5" BFG or Goodyear 37" (5@$175)
Total = $1,823
Or
Hutchinson Rockmonster double beadlocks at (5@$420)
17" MTR's 37" (5@$365) tirerack.com
Total = $3,925
Pretty nice savings when you look at it like that!
Total = $1,823
Or
Total = $3,925
Yeah man I was just figuring this out. Depends on shipping but 37's are $100 at that other site 100dollarman.com so possibly slightly cheaper
