4 link works well, but for the effort a bolt on has for an 80 is to many compromises over using 12s with standard arms.
This truck has had this 4 link with panhard since about 1999, after having flipped radius arms before that.
It uses the lower original chassis mounts. It has spaced bump stops, and 12" stroke shocks, so effectively with stock bump stops could run 16" stroke shocks and allow that to still have more flex available. [truck runs 38s for play and 35s for "overlanding"]
This truck will drive to almost full flex in 2wd normally, due to how easily the travel comes with this set up.
The sway bar in this one has been specially made and is like the rear a little now, connected to the chassis a bit like the rear and runs down with the arms, across the front diff housing, instead of the opposite with a standard 80 front set up [this truck is an 80 chassis, 75 body, 79 front, 512 c.i injected big block]
We have been working on this kind of set up with 16s front, and using a rear a frame that replaces the upper arms, with 1 foot longer lower arms and 17s in the rear. We have 17s here to experiment with this rear set up in an 80 we have here specific for the purpose of doing both front and rear in the one vehicle, to maximise its travel, but it wont be bolt in At a max 3" lift, with double slinky coils to stay captive in the rear, and coil over fronts.
The coil over kit goes in the coil position, and has the axle forward 1.5" as well to clear 38s to the firewall with a little work. Adjustable 4 links also can give more with a new panhard rod design to make more clearance.
For the record, the patrol needs the 4 link more than the 80,
[check the pic of the patrol 4 link, and its seems you need your shocks undone to get it flexing
] as it takes alot to get 12s to work in the front of a patrol, where as 12s work with standard arms in an 80.
[my patrol in around 2006 with 12s and 14s triple bypasses on 37s with drop boxes and all the other stuff patrol needs to work]
The other thing with patrol and its huge front diff, is heavier control arms hjust add to the unsprung weight....
12" fronts standard 80 arms, 2 deg bushes, washer mod, sway bar spacers.
Ideally we just need fiberwerx or someone to make some new fenders with 3" lift front and 2" out, and rear flare 100mm longer so the axle can go back 2" to leave the doors alone, but the rear fenders can be tubbed and extended so we can run 16" fronts, 17" rears, and 40s on 20's with a under 3" lift.
[My red patrol had 1.5" higher and 3" longer standard looking flares to fit 37s in the pic here]
