Bolt on front end 4 link possible?
Gladstone Qld
This popped up on my Facebook news feed this morning. It's for a Nissan patrol but I wonder if the concept could be adapted to our 80s. Would be an awesome upgrade. Thinking I'll send them an email regarding a version for our rigs.
Thoughts?
Interesting. Seems logical that they would offer one for 80's. What's the cost of this 4 link apparatus?
Move the sway bar to the front of the frame
all the photos I've seen of nissan patrol front suspension look very similar (like, nearly identical) to an 80, so in my very uneducated opinion, I don't see why not?
4 link flexes better than radius arms
I see two problems with this on an 80:
1. Tierod
2. Swaybar
Invert the mounting brackets on the axle housing and run the tierod between the control arms?
Leave the sway bar off ifn your really gonna wheel it!
Not happening without investing a lot of time and money. There's just no room to make it work mounted towards the front.
Then it's not really a bolt-on system. Might as well DIY the whole thing in that case.
I think the Superflex arms are about as good as it gets for the 80 as a bolt-on solution before you start cutting and welding.
I disagree.
I think the OE arms are as good as it gets before cutting and welding.
This:
at the furthest stretch of catch phrase verbiage, is a '5 link', catchier '4 link with panhard'.....but personally think cluge job best describes.
An adjustable radius arm with separated upper mounts....
Nissan Patrol front suspension are pretty, but I mean pretty close of what we have in our 80 .. ( Patrol Y60 / Y61 )
1. Tierod
2. Swaybar
The tie rod is between the two in that picture.
Please, let's not bring them into this.
I just rang them and no, no plans for 80 series worse luck.
Why does that arm look like it's not attached to the frame? How does it clear the pitman arm?
Was a mockup/joke I saw elsewhere online. Thought I had typed that out saying so, but I guess I forgot.
EDIT: Wait a minute, you noticed that instantly, but didn't notice the tie rod on the patrol pictures? :flipoff2:
Ha! Got me all excited. I was like hold on, this looks like bad photoshop. Fabricating is easy you can copy/paste drag/drop.
At least, they're selling on car adjustable castor and a beefy bash plate. Apart from that, there's nothing to gain.
It's not anything different, functionally speaking, than what exists below the 80 now (except the separation at uppers, which makes little sense) just 10 attachment points, instead of 6.
There is a lot of misinformation in this thread. Geez. Links are more than just flex. Suspension geometry is a complicated topic and to say a hypothetical system wouldnt work is just short sighted.
Could a bolt on 5 link work? Yes.
Is there one now? No.
I made a semi parallel 5 link that allowed retaining the tie rod and sway bar. It worked. It flexed. It kept the same roll axis as the oem radius arms. Etc. I have a thread on here about it.
