FJBen
Oh I"m 100% for getting it running as is just to drive it. I have nothing against a V8 in a 40 at all. Good luck on the engine, I think it's worth spending a little time trying to get it rolling.We are trying to resurrect the 327 to burn some rubber. It would be a thing to say we did in a 40. We had high hopes of adding some ATF or Marvel Mystery oil to the cylinders last weekend. Tried all the spark plug sockets I had for cruisers and more. None of them worked.. Heading to the barn with @SipLife this week to do a Take 2. We tried to push bump the motor in gear but the crankshaft pulley whistled Dixie.
So, I've been doing some thinking about Bluebonnet's Future Mechanical setup and need some advice:
I've been thinking about doing a 4 wheel disk break setup on Bluebonnet. I already sourced FJ62 front disk break components for the front axle and am considering the JT outfitters rear disk break conversion kit for the rear drum axle. We also have a spare H55 and Split Case in the shop that could be put to use in Bluebonnet. The only issue is when swapping from a single to split case I will loose the parking break on the T-Case. I have been doing some research on Mud and IMO the best option is adding the parking break to the rear axle. It would be cheaper than sourcing an 80+ FJ40 rear PB axle. The only downside is that I would have to shorten the rear driveshaft. What are your thoughts on this? What PB setup would you recommend and why?
Here is a helpful thread I found on FJ40 PB options:
FJ40 Parking Brake Options
forum.ih8mud.com
H55 would be great in here. I had the JT outfitters rear disc on a 40 before and it worked well. The parking brake on the kit worked OK at best. IF you buy it all new thats $600 from them. Looks like they still use the monte carlo calipers.
Food for thought:
T-case parking brake. This is an option, however I remember people stating it wasn't quite strong enough to hold on big inclines. Now maybe it's my fading memory? Maybe they don't make these anymore, I haven't had to search in awhile. Also, possible drive-shaft shortening issues.
70 series axle: I believe they are about 1" wider than the 40 series axle. This would also give you fine spline and help with matching the front if you are swapping to 62 front brakes as I believe those make it wider as well. I know @joekatana is in Texas and has lots of 70 parts. Most people want the full floater, so it's possible you could pick up a semi-float 70 axle with drum brake/parking setup, upgrade your axle and be good to go?
60 series rear drum parts. Now these are much easier to get, but...I don't know if they bolt up to a 40 series axle. It might take some research on that and what is all involved. I'm sure you could distract @CaptClose long enough to borrow parts from his 60.
Line Locks. These are cheap and work great. However they don't work in a hydraulic line failure issue and it's possible some cruiser events won't let you pass inspection for trails with one. I believe Cruise Moab is one such event, I'm not sure if any others have that stipulation.
All of these ways will require you to figure out a parking brake handle/cable setup.
They all have pros/cons so check them out and see which would be the best fit.
