actually no they are not. All the clutches are set the same and have been since I started this thread. If they are setup different than this they are doing it on their own.
You are correct the ones YOU mod are the the same.
Well, this is my thread about my mod. And that point is important to me.
Thanks Guys! I tried my 93 black hub set at 95* w/15k earlier in the summer and the temp moved up a little bit but not to red on a NorCal 100* day, 70 mph on the highway, loaded with no trailer but a Yeti 105 cooler mounted in front of the grill.
I modded a spare blue hub to 95* and 20k and put it in the same truck. This weekend I went back up to the NorCal mountains loaded heavy, pulling a loaded trailer (maybe 3-4k) with the Yeti mounted on it's rack in front of the grill and the AC blowing cold air the whole time in outside temps ranging between 98 and 109 on the highway @ 60+ mph and slow winding steep grades through the mountains. The temp gauge stayed between 2/5 ths and 1/2 and never went above 1/2. I like how cool it ran but I must say that it sucks air like a 757 and does rob some of the much needed power and mileage went down a bit. I may stay with the blue hub and try 15k or maybe try 20k in the black hub just to compare. Before I do any more testing, I'm going to do the RavenTai gauge mod using 100/150 ohm res. so that I get a better handle on temp movement. But because I carry my cooler up front, I can't depend on ram air during the hot weather. Dan
If you are basing your temp gauge movements on a stock 80 temp gauge.... you're in for a big surprise after you install the RT mod. Yeah, the stock gauge barely moves...until just before it overheats. Then it's practically too late. To be honest, I'm surprised you didn't install an aftermarket gauge to get an accurate reading before going through all these trials with the fan clutches.Thanks Guys! I tried my 93 black hub set at 95* w/15k earlier in the summer and the temp moved up a little bit but not to red on a NorCal 100* day, 70 mph on the highway, loaded with no trailer but a Yeti 105 cooler mounted in front of the grill.
I figured it was overkill but I knew that it was going to be hot up there this week and I wanted to play it safe as well as experiment. So are you thinking I should stick with the blue hub @95* and drop the oil to say 15k? I really liked the airflow that I got with the 95/20k even sitting at idle for 45 min. waiting for construction at the Buckhorn Pass in 106* it kept it nice and cool but I want to bring it down to just what it needs and nothing more. ...
Hi, can any fan clutch get rebuilt with this mod? I have a 94 FJ80 and you can stop it by news paper.
There no clutches local can I rebuild mine?
