BJ73 Gearbox ID (1 Viewer)
Europe
Hi,
1992 BJ73 VM 2.5TD - I believe the synchros are going in my gearbox..
Figuring out the best move forward, rebuilding or sourcing another box (which might be in the same position later..)
I am trying to find what gearbox ID I have and if I can source one from another Toyota. Struggling to find any part numbers on it!
Cheers
Looks like an H55f, but check the data tag on your firewall to confirm.
Some old info from Delancey, brought this up about the h55f:
The VM'd BJ73s use an F/H input shaft, F/H clutch slave, and F/H clutch, F/H flywheel.
I'm not sure that was ever confirmed. But If any one confirmed it and went through the trouble to do so, it would have been Chris.... RIP. :(
Yes, VM use the F/H input confirmed. I helped with installing a 2F into a VM-equipped BJ73
33030-60450 will be a direct replacement.
Not a great pic but you can kind of see the 10-spline
