For Sale Birfields, Drive Flanges, hubs, axle shafts, spindles, calipers (2 Viewers)
Deathvalleypaul
FJ80 Collector
Near Pasadena CA
So Cal BIRFIELDS for 93-97 ARE SOLD, NICE PAIR OF SHORT BIRFS NOW AVAILABLE, $100 EACH INCLUDING SHIPPING.
Backing plates, Spindles, Axle Housing, Tie Rod, Axle shafts , Drive flanges, Relay Rod (Drag Link), Sway Bar, ETC ETC ETC
Parts available for 91-97 Cruiser or LX series.
From a 1997 FJ80 Land Cruiser - parts will interchange with LX series .
Prices run from $25 to $110 per part. One Set available.
NO
I need a spindle and I’m usually cheaper than a flat rate box at 95361. The two big skinny nuts for the end as well if they’re around.
If the calipers are in working order and are ready to simply bolt on (pad change doesn’t matter)and drive Id be interested in those too.
see your personal message
right and left birfs and axle shaft prices please
shipped 29693
Any chance it wont cost $1M to ship the hubs?
i can ship both hubs for $17.90.
See your personal message
how much for the front axle housing I would just pick it up
I have a couple empty housings right now. Please see your personal message
I have a good supply of knuckles, spindles, front hubs, front axle shafts, drive flanges, and front axle housings for both ABS version and non ABS version FJ80s. I also have some birfields for 91, 92 and early 93 models
Do you have 60 knuckles backing plate forward? Need some to convert fj40 to disc brake.
I don’t.
Happen to have long side rear axle shaft for semi float ‘86 FJ60?
Thanks
i dont have any 60 shafts.
Available. One knuckle is $98.74 including shipping as long as it fits in a large priority mailer. I will check it for fit in the morning. If it requires a larger box it will be $16 more.
