Ali,
did you carefully check the face of the rubber seal? I remember some people using the seating tool that wwas not wide enough and cutting the face. You can probably only see if if you tug on it.
Otherwise,
I noticed the Marlin seal rubber was not as flexible but seemed a much beefier design than OEM.
The outside of the seal (that faces the axle) has a thin, orange/red seal. Maybe that seal is not thick enough and caused some leakage?
bummer you had to tear down
Otherwise,
