- Thread starter
- #41
The new shock mounts allow my 18" Doetsch Tech to soak up all the compression and droop.
(I also moved the rear shock mounts to the backside of the rear crossmember this summer, and moved both of them in towards center about 3 1/2")
And just a scenic shot or two...
I then cut a
down to fit inside the frame rail to hold the nut while I tightened the bolt head. But hey, it looks stock!
) I then used a drill bit big enough (I think it may have been 5/8" or 19/32") so that I could easily get the bolt through the holes. (I would recommend using a right angle drill if you have one as it is a challenge to get a drill up in there.) I then cut the heads off of the bolts so that they would look factory from the backside, stuck them in, and welded them up on both the front and back side. I basically mimicked factory mounts, but unfortunately using SAE hardware.
