bib light turn signal mod
Maryland
So i decided not to run the large turn signals of the fenders of my 1976 40. I used Toyota original bib lights and modified them to work
with he existing wiring. I put it up on you tube for easier upload. I hope it helps someone some day,
This has been done for many years. On the FJ25 bib lights were used as turn signals and parking lights. When then FJ40 started the same bib lights were used. Originally the turn signal wire was still there, just not used then deleted. These lights were also used as tail lights on the FJ25 and first couple of years on the FJ40. I have a few set modified as tail lights using reproduced red lenses. We just got lucky Toyota never changed from the dual element lamp and just deleted the wire for the unused element. Simple job to just solder in the needed wire.
I usually just take the plug apart. B4 scrapping a rusty housing I scavenge the parts.
