Customer picked up this '40 today. Called me when he got home to tell me he LOVED how it drove now, and that it totally ignored the ruts that used to lead it around by the nose.Rut Slut…..I love it!!!!!!
Add Skyjacker to your OME list to add 2 degree shine with a 2.5” lift. It’s awesome the customer was happy with your ‘wrenching’.Customer picked up this '40 today. Called me when he got home to tell me he LOVED how it drove now, and that it totally ignored the ruts that used to lead it around by the nose.
Mark...
This particular rig is one of those very nice ones that seem almost original stock at first glance but with a lot of quality upgrades once you start to look closely. It has OEM manual steering right now, but I expect that retrofitted OEM PS or minitruck conversion might be in the works before too long.Add Skyjacker to your OME list to add 2 degree shine with a 2.5” lift. It’s awesome the customer was happy with your ‘wrenching’.
Question, did the customers rig have stock manual steering or was it power….something?
Factory spec is 1-2 degrees. 3-4 degrees drives better IMO.Hey all,
At the alignment shop. Where should my caster be with the OME lift?
That is bad caster. Any worse would be a nightmare to drive. Those numbers say that is sucks to drive by my standards and expectations..Thanks!!^^
Here are the specs below. Caster wasn’t as bad as I thought it would be.
What shims and center pins would be recommended?
@pb4ugo - circling back to your post here and I also just put in a 2.5" lift and having some minor wandering issues. Prior - have completely rebuild my front end, hubs, rag, etc. Truck was driving really nice before lift with all the new steering parts and aligned. After lift, just some minor wandering.You need to know what your caster is , so youll know what degrees shims you'll need. Get the vehicle on level ground, equalize tire pressures and make dure the vehicle is level. Using a angle finder check your current frt caster. In the pic below, pretend the level is the angle finder. Don't use the nuts or studs. You should be able catch the bottom edge of the bearing cap.
I install my caster shims differently than others. I found when tightening the center center pin bolt with the shim installed, the head of the bolt distorts/bends because of the angle of the shim and weakens it.
Sorry about that… yes, driver side picture has the front of the vehicle on the right side of the picture frame, and passenger has the front side of the vehicle on the left side of picture frame. So 1-2 degree negative caster.@pb4ugo - circling back to your post here and I also just put in a 2.5" lift and having some minor wandering issues. Prior - have completely rebuild my front end, hubs, rag, etc. Truck was driving really nice before lift with all the new steering parts and aligned. After lift, just some minor wandering.
I used a cheap angle finder per your directions above (thank you!) - the pass side bottom end of bearing cap was not as present, but did my best. with my pics below, can you tell me if I am negative caster or positive here? Assume negative?
From these basic readings, was considering 4* degree shims to help put more positive into my front. I plan to go with 33x10.5x15 tires this summer (currently have 31's now).
Driver's Side - looking at back of wheel for reference
Passenger Side - looking at back of wheel for reference and my fat fingers
Got it…my mind is running backwards at timeFat side to the front. Ref the sketch I posted to achieve positive caster.
The shim is held in place by the clamping force of the ubolts. if the shim can shift... your ubolts are not tight enough. Any play around the pin is irrelevant.Quick ? all,
In the middle of doing the shims.
The centering pin for my OME springs is smaller than the hole on the CruiserTeq 4* shims allowing for a bit of play in the shim. My OME centering pins and leafs are more like 5/16" and the hole on the shim is 3/8". Don't think I am drilling out the leaf pack. OK to run a 5/16" pin with the 3/8" shim? The head sits fine in the recess. Pics below of the OME pin in the CruiserTeq shim.
