best water pump? (3 Viewers)
about to put a new water pump in my 1969 fj40. anyone have a suggestion as to which manufacturer i should use? thanx
This is what you want, Matt will hook you up.
I put one in my '69. Upgrade your fan and hoses while you're in there.
He sells that cool overflow bottle too.
Can’t beat buying from Roger. No need to pay double.
I had a rock auto waterpump on mine previous to this one and it wasn't the same and it failed. Maybe they have changed?
Rockauto doesn't manufacture parts, they are a reseller (which I am sure you know). They resell 5 different brands so in order to say one failed without stating the manufacturer isn't a reliable datapoint. If it is a GMB that you bought, and the markings on the pump show that, then it is a good datapoint.
Wasn't an aisan, gmb, toyota, etc. And they didn't have 5 when I purchased. My data point is just my personal experience with the unit I got from rock auto. Anyway, like mentioned for the original poster, you have plenty of options for good parts. I buy from cruiser outfitters and city racer too. I think my metal fan replacement was from city racer. Great to have lots of vendors helping us out! :)
with all the various opinions above ...:rolleyes:
- there are MADE IN JAPAN GMB water pumps = they cost more
- there are GMB ones NOT made in japan = they cost LESS
If you do get a GMB pump and wouldn’t mind, would you take & post a pic of the outlet hole on the back side? I never got an answer in “THIS” thread, so I still don’t know if it’s normal or if I got an odd ball. Perhaps it’s due to country of origin. I have no idea.
GMB Image from ROCK AUTO right now
Thank you Matt. 👍
your welcome
well that's the ROCK AUTO image
i DO stock A few of the real JAPAN GMB;s
i have never noted this ?
stand by
Thank you Matt. 👍
Ok
Here is my made in Japan GMB. I offer
They do cost approximately double the ones the 2 folks sadly bought above made in China …
Here u go my friend
You
To add to this it's not just about brand or if the pump is made in Japan but who you buy from may determine how the part was treated/stored before you purchased it. I got this fine pump from Rock Auto at a good price and it came with an extra gasket for some reason, when I opened it up to put sealant on the gasket I was disappointed to find this.
Ended up having to sand off the corrosion on the plate and use the "extra" gasket before I was comfortable that it would not leak.
thats not normal cheap jobber but hope it works for a long time
I've read through this twice, still have questions. After speaking to 2 different "expert" online Cruiser people (and getting sent the wrong part), I still don't have an idea on this.
I have a 67 FJ40 with a 78 2F engine. The radiator is in the stock location. A long water pump with the tall double pulley and the plastic fan is too long, the fan hits the radiator.
Can I use a short water pump, a short double-groove pulley, and a plastic fan? I don't care about a fan clutch.
Thanks
OK so update then... Found out on this thread:
The radiator support can be moved. So I pushed mine forward, and problem solved.
Tons of room now
Almost as if Mr. Toyoda did it on purpose. The red circle is the new location for the rod from the firewall.
Here u go my friend
Hey Matt, I just noticed that I missed responding to your second batch of excellent photos. Apparently, the casting & back plate alignment I pointed out seems to be normal. Even though it is normal, it did not sit well with me, so I took a die grinder to it and removed that portion of the casting and smoothed it out. When put just the backing plate up to the block, I could see the opening in the water jacket was larger than the hole in the backing plate. So, I even relieved a little of the backing plate hole edge to provide a smooth transition into the block.
Did it help? I don’t know because at the same time I installed my freshly rebuilt head which cured my vacuum issues and it’s running much better. It is cooling better, but I have no idea if my pump mod plays a part in it. If I ever replace the pump, I will do the mod again. I really wish I took some good before & after pics because it did come out looking good. Maybe a waste of time but who knows without some accurate testing.
