Mace said:What is the benefit of closed chambers and flat top pistons?
And yes, this motor will get flat abused. I am looking at well over 200hp at the rear wheels...
And a 6500K redline..
So, every little bit of work will help![]()
Chef said:So Mark, are you just buying psitons and rings and cams etc at Napa as needed?
Northern has "kits," but they're way more than what PacLift used to charge...
Mace said:So basically, an 84 or 85 block has the best of all worlds in a 2F.
The compression ratio does not worry me particularly due to the turbo, But that is excellent info to have.
I already have over 140 hp at the rear wheels (sm420/dual mini tcases/and a 14 bolt), and that is a Stock motor with over 150K on the ticker. I am thinking that a healthy cam and good balancing will let me get up to the 200 RWHP numbers.
Which bigblock bolts are you eyeing???
BTW, It sounds like a 76 2F block would NOT work with a later 3fe head due to the flat top/dome pistons correct?
BTW, as I assemble this motor I will document it and the Dyno results afterwards....
andrewfarmer said:Over here, I've never seen domed pistons - everything was flat top.
Mace said:Nah, I like the longer stroke. I see no reason to destroke the motor. Besides, the 3F stroke is not that much shorter than a 2F...
I wonder if the side loading of the piston is offset by the reduced weight of the rotating mass??DHONDAGOD said:the shorter rod also reduces torque (piston dwells for less time at TDC)and increases side loading of the piston...
chris![]()
Now all I have to do is figure out what engine # they started doing all of these modsFJ40Jim said:Mace,
If you had to pick one 2F to build, the 85-end models are best. They have all the upgrades of the 81-85, plus in 85 they got:
-the 3F cylinder head, which gives the option of running the 3F manifolds
-the 3F head gasket with better coolant flow direction
-screw in oil galley plugs (I really like this)
-slight improvement w/ the 3piece thrust bearing
-torx screws in timing plate(which should be added to any engine).
However, if you start w/ a 4230cc engine that is 8.3:1, then punch it 1.5mm OS, the result is 4367cc at 8.57:1. Usually the head is milled a little to clean up the face, which will get up to 8.7:1. If the engine is gonna be blown on, that's a pretty high CR, without modern feedback control systems.
The lightened valvetrain came along in mid 1979.
On the rods, newer is definitely better. As Mark mentioned, it's marginally lighter, but it's also much stronger because of the extra finishing on the I-beam.
I've got a picture here of the 79-earlier rod vs. the 80-later rod, but can't figger out how to post it.![]()
If the engine is gonna be spun, it should be balanced to zero. Early 2F and all F engines are often out by several OUNCES. No, not grams. Rods are out by 20 grams or more, cranks off by 50, flywheels off by 30. The only thing that keeps a 1971 F engine together at speed is sheer stubbornness. The 81-newer engines were destined for cushy FJ60 wagons, so they finally started paying attention to balancing. They are usually only out by an ounce.
HTH
