Mace said:So you could do a "stroker" 2F is youi wanted to with an offset ground crank![]()
Here you go putting a racing saddle on a jackass again.......
Mace said:I thought you weren't comin out to Moab???
4x4Poet said:Gapless rings do retain heat in the combustion chamber more so than regular rings since less blowby releases less heat past the pistons down the cylinder walls, so cooling capabilities must be a little better than when running regular rings. Higher compression exacerbates this, of course.
Mace said:I typically run 180* when it is 110* outside...
Does that make you feel better???
alkaline747trio said:Lets say this will cost me $300 to do, would it be worth the effort to do this?
alkaline747trio said:Also, what other mods can be done for more power out of this 2.5FE creation while remaining naturally aspirated?
