Builds Benjamin’s 3D Prints Build (10 Viewers)
Hi Ben.
Simply amazing work!
Just gone through all 159 pages… took a while.
Plan to order a few items… just haven’t found the 100 to put them in yet.
What’s the order-delivery time?
I’m in Spain, but over in Columbus in November for a week with work so maybe could come and collect from you direct?
Cheers
James
James,
You gone through 159 pages? Thank you.
I am preparing my own webpage. It should be ready in about 3 weeks.
I moved to Michigan.
You can message me or email me for ordering.
Need help identify these connectors
Are these the foglight connectors for LX470? Which one is on the vehicle side, which one is on the foglight side? Thank you.
These are from the fog light in my 2000 LX470. The one without the red gasket is attached to the bulb side. The one with the red gasket is attached to the wire harness.
James,
Hi Ben
Yeah, went through all of them, found lots of stuff I never realised I needed…
I’ll email you shortly with the order request.
Couple of questions here though…
Are you planning to make the LED fog light mounts for LC/LX using the BajaDesigns Squadran-R SAE lights?
Can you use these Stedi switches in your designs? I believe they are OEM Toyota sized at 39x21mm and pretty sure I read you can use OEM switches.
Finally, what software do you use or would recommend for someone to get started on? I’ve used used SketchUp and Shapr3D a little.
I’ve got an old BMW e30 coupe and a few other projects where 3D printing could be really useful.
Cheers
James
Hi Ben
Cheers
James
Thanks.
Not going to support Squadron-R for dual LED each side. For single LED each side, it is possible.
I can accommodate these switches.
I use Solidworks. I have a permanent license. All industrial 3d softwares are capable of handling 3d print design.
Hi Ben
Cheers
James
Fusion360 is a great program with a lot of tutorials on YT. You can also get it for free for personal use.
Hi Ben!
Any chance of an M2 V1 LEFT?
Make 29 V1: Second-row Cupholders Replacement
1 Overview of the Final Product
2 Description
M29 is to delete the second-row drawer/cupholders and set up a power distribution hub.
The bracket connects the factory panel to the rigid factory mounting points, providing a solid base for the faceplate.
The faceplate is customizable on CAD level to fit various devices.
V1-V5:
A potential use of RAM ball mount:
RAM Diamond Ball Base:
120V Outlet
12V Socket
3. Purchase
$150
PM for paypal info.
What you get:
  • Bracket
  • Faceplate
  • Fasteners
  • 12V socket installation tool (Need this tool to install the threaded ring)
I wonder if anyone else is like me and is dying for this with Ram Ball in the middle so I can mount an iPad with an arm for my kids in the back and have the screen raised up and centered. Ram ball in the middle for IPad and then Ram ball on each end for cup holders and then 2 USBs or 120v in the other two slots for charging phones and iPad would make this THE ULTIMATE “Kids 2nd row”. If this is ever something you decide to do I’ll be your first customer 🙏🏼
Sure. I can do it. Stay tuned.
Edit: sold.
I have a brand new Make 5 (Scanguage II mount + 2 rocker switch panels) in gray I didn't end up using. I installed two rocker switch blanks but never installed the Scangauge II. Anyone want this, how about $75 shipped? I'll also throw in the ethernet extension cable and adapter recommended for install that I also purchased but never used (~$15 at Amazon).
Make 59 V1: AUXBEAM Switch Panel Mount
1. Overview of the Final Product
2. Introduction
M59V1 mounts an AUXBEAM Switch Panel in the overhead console.
3. Purchase
$100 plus shipping.
So which Auxbeam panel does this mount hold? Looks like there is a "compact" 8 panel switch and an XL 8 panel switch that is slight larger. See Auxbeam Switch Panels | The best way to control your electrical access.
